#2 : +10% (but is going up to +15% or more as its still hotter than the rest)
egt is a funny beast, and almost borders on reading tea leaves without additional data.
Adding fuel is roughly equivalent to retarding the timing, so you might get better results
leaning it out.
retard the timing and watch the egt...
Setting up an injection flow test rig is pretty simple.
The spray pattern is ~just as important as flow.
Unfortunately 4 WBO2s are the only way to be reasonably sure what the EGT is
really telling you.
Then you can play with the ignition trim tables and expect pretty even results.
Perhaps move O2 sensor around and tune each bore if you have the bungs installed, and have the required trim tables.
(I'm considering that, as I have a spare WB, and welders)
Mario, are you running the extended bungs and/or heatsinks?
It's pretty easy to overcook a sensor when they are upstream of the collector.
