Engine build almost complete
Re: Engine build almost complete
The main thing beveling the edges accomplishes is knocking off the super hard edges.
The sharp "outside" corners are almost diamond hard, can dig in and can even chip off.
(gets nitrided from both directions)
AMBROSIA
Post by AMBROSIA »
Borescope arrived today so will have a poke around this evening.
As a quality camshaft maker i'm surprised they don't do this procedure in the factory.
From what I've read there is likely to be some damage to the oil pump gears from any edge flakes that come off but will be caught by the oil filter.
Not liking the sound of this although replacing pump gears is a lot simpler than a full strip down which I am loathed to do.
buildabiggerboxer
Post by buildabiggerboxer »
Hmm, it is annoying, but If you find you do need to strip it, you will have to bite the bullet, if it's any consolation, I must have chewed up a few amo belts worth and even now days still have grief with modded motors, it sometimes comes from nowhere, wham, like my sticking inlet valve after 3 years hard use! It's always best to jump on it before cost factors increase. In my turbo days a wasser cam and lifter change was often done in about 6 hours, I do an Aircooled in about 3 or 4 hrs, key off to key on, with my race motors the dry sump pump, hardware and hoses etc are about the worst of it, but time and the needs must basis proved the fabled complete strip isn't needed, set it on #1, leave 3/4 side Head and p&l's, just pull the left rocker shaft and push rods etc to unload the cam, oil pump needs to come out, then pull all the right side hardware etc as normal.
AMBROSIA
Post by AMBROSIA »
This is certainly my plan as now's the time to rectify any issues.
I do have the advantage of a dry case inside, so no oil/coolant goop dropping everywhere :lol:
Should be just enough magic glue left over to re-do the head gasket.
AMBROSIA
Post by AMBROSIA »
Got the borescope going but the clarity was so poor and trying to hold a suitable viewing angle was impossible.
So, bit the bullet.
Had to make a temporary 'shade tree mechanic' engine stand, but it worked fine.
Had a good look at the cam lobes and other than the casting areas it looks pretty even all around.
You can run your finger firmly round the edges and not feel any cutting or sharpness.
How much should I take off the edges to be safe assuming the lobes are suitable when I check tomorrow?
An old credit card works great at breaking the gasket seal to the head without damaging it :D
Plastic bondo applicator works good too.
I knocked off the edge by hand with a coarse diamond hone, didn't remove much, just enough so it had a ~1mm bevel..
buildabiggerboxer
Yes, as above, 1 mm is plenty and as large as you need, be careful, I run low air pressure to keep the revs down and limit any finger slip/judgement damage, tape the journals near lobes just in case, keep the stone speed down, finish off and smooth with a small oil stone, those hard lobe edges can rip through rotary stones in short order, don't forget a hot soapy scrub up and wash, then liberal WD40 and compressed air blow over.
Might be a faff to far, but You could drop the cam wheel off, cam back in and case half back on, Mark/blue up a lifter or two and drop them in, turn the cam via the oil pump aperture and take a cam lobe wipe snap shot, finger pressure on a lifter should be enough.
buildabiggerboxer
Just an aside with cam wheels, put extra torque on the bolts, I do 20ft/lbs, I've seen 14ft/lb quoted on cam makers web sites, taint enough, they can come loose at that, I've seen it.
AMBROSIA
Post by AMBROSIA »
Ok, beveled the edges as best I can.
Used a file to carefully smooth the edges, which took a couple of hours.
As suggested it was cleaned with soapy water and some wd40.
The cam wheel bolts were torqued up to 18 ft/lb but no harm in redoing to 20 to be on the safe side.
Regarding the lifter/lobe compatibility, I thought a small video would be ideal.
http://vid9.photobucket.com/albums/a64/ ... cjsx0t.mp4
It's difficult to hold the camera steady, rotate the cam and apply pressure to a pushrod, but from what I can see it looks marginal.
Thanks for the help guys, it's really appreciated :)
Steve Arndt
Post by Steve Arndt »
Marginal, it sure does. Appears to be wiping the edge of the follower against the lobe.
fastback
Post by fastback »
As BBB also suggest i put some "color" on the surface on the lifter , paint marker, blue stuff, or you can use a 1K primer to cover the contact area.(washes off easily with thinner afterwards)
then do the test as in your video. turn the cam several times the way it rotates.
the cam lobe should not wipe away all the "color" on the outside of the liftersurface.
you should see a small area in the outer part of the surface that still has color. then it is OK
if it vipes away all the color in the area the lobe faces the lifter ,it will ride on the egde
fastback
Post by fastback »
AMBROSIA wrote:Done some more research.
From the Web Cam site:
86b
Designed for large displacement racing engines. Works well in a off-road application. Great torque! WEB CAM mechanical lifters required. See part #00-265.
For the 86C they also recommend the same lifter so I would say JC @ stateside errs on the cautious side.
Looks like this combo should be ok, but still going to check as best I can.
and i asume this quote is from the Type 4 section.?
AMBROSIA
Post by AMBROSIA »
Yes, this refers to the T4 web 86b/c and solid lift combo.
I will be trying the marker pen test tomorrow to see where I stand.
If it's not compatible then I will be sourcing an 86a with the reduced lift and duration.
Will be a shame, but nothing a set of 1.4 ratio rockers won't fix.
TBH the 86a was my initial intended choice but there was no stock when I came to purchase :roll:
fastback
Post by fastback »
you can convert to type 1 lifters
i use some German alu bushings that presses in the WBX/type4 bores , and does not need any reaming afterwards
AMBROSIA
Post by AMBROSIA »
I did look at getting the case machined for T1 lifters but the cost was too high.
Now that you mention this I do remember reading this somewhere as an option.
Do you also have to machine down the bore tops for lobe clearance?
