Rear camber
FJCamper
Re: Rear camber
Post by FJCamper »
Here you go.
FJC
ONEBADBUG
Re: Rear camber
Post by ONEBADBUG »
Yeah, but ...
You're changing ride height as much as camber. Since the inner pivot point can't move, you can't change it very much.
RHough
Re: Rear camber
Post by RHough »
ONEBADBUG wrote:Yeah, but ...
Don't want or need to change it much. I just need to get the thrust line square and the rear camber even and as far negative as possible at stock ride height. The last "4 wheel alignment" was a just front camber and toe. Not happy and the shop that did it is 6 hours away so I'm not going back.
Next alignment question is ride height. I'll assume since the front is stock not adjustable that the front is correct. I've seen no hard measurement for a 1972 Ghia ride height and I have read that the rear should be 1" lower (measured where?) and also read that the car should be level as measure on the sills. None of this was a problem with the stock DP engine, but some interesting handling has shown up with 120+ HP on tap.
Cheers,
Randy
