IDA Throttle Bodies
Dive!Dive!
Re: IDA Throttle Bodies
Post by Dive!Dive! »
Luke - have you tried hybrid Alpha-N ? I have Pauls 38mm ITBs on my 1776. I use a TPS/RPM map for fuel and a vacuum (load)/RPM map for spark. Mine is a pretty robust 1776 (125-130 at the flywheel) and it couldn't be any more docile round town. Just a thought.
Steve
UKLuke72
Post by UKLuke72 »
Hi Steve
I'm still learning a lot about the tuning side of it all.
Interesting you say about running hybrid. Tbh I'm just running speed density for the primary load on both the fuel and spark. Not sure if that's the best way or not but I'd be happy to try setup like you refer to.
dangerboy
Post by dangerboy »
I know old post, but these look like what I need to fit in an early type three. I was toying around cutting and welding the manifolds to turn the injectors in. This seems easier. Can anyone link me to Paul’s site?
UKLuke72
Post by UKLuke72 »
dangerboy wrote: Tue Sep 08, 2020 1:47 pm I know old post, but these look like what I need to fit in an early type three. I was toying around cutting and welding the manifolds to turn the injectors in. This seems easier. Can anyone link me to Paul’s site?
https://vwspeedshop.com/home.php?cat=395
It's not always up to date so definitely worth emailing Paul with your requirements.
