theKbStockpiler wrote: ↑Sat Feb 03, 2018 9:50 am
I basically wanted something to hammer on and also add to my capacities as a metal worker. Sometimes I would like to be able to bend a curl so a bolt will go through it or make a hook for hanging. Maybe I'll buy a piece of RR track off of fleebay. I bought a HF vise ; the one that the jaws rotate, and the anvil is so soft that if you try to flatten out a paper clip it will put a grove in it. I'm not kidding. :lol: For just clamping it's good but it is not going to hold up to hammering use.
I can't imagine a horn that is good for anything that is flat on the top.
A vice is not a anvil.... A vice is to hold things while bending, cutting or drilling and are usually cast iron...
And if you really need to pound on something being held in a vice, you need "leg Vise"
Cast Iron vices can be broken vary easily... A anvil is nothing more than a block of steel.... If you just need something to "pound on" go to scrap yard and get a chunk of scrap "steel" ( at scrap yard prices), anywhere from 5 to 50 pounds... Anyone selling you a cast iron anvil with flat horn (although most anvil horns are not perfectly rounded on top and you work around sides of horn) is gambling that you do not know what a quality anvil is or how to use one, Chinese marketing...
If you really want a "anvil" the two most popular designs are "London'" pattern and "Farriers" pattern... Go to some place like Centaur Forge or Pieh Tools and get a anvil weighing in anywhere from 70# to 150#... Be aware a good new anvil pricing start around $300 and goes up from there, Since the program Forged in Fire came on the tube, prices have soared out of sight, good used 150# Trenton or Hay Budden or Peddinghaus can go for $6 a pound (150 # = $900) or more... Easier on pocket book to buy new anvil than used today...
Harbor freight and like places selling small cast iron anvils are not your friend....
This is my 100# Vulcan with tool steel top plate and cast iron base, on scale of 1 to 5 in anvil world its about a 3.5 to 4 and has about 70% rebound.... 5 years ago it was $200 used... To day up to $350....
Dale
