Supercharged 1600 EFI - Dyno Video Page 6
Re: 1600 EFI Supercharged (100hp?)
Man this is pretty cool. Been wanting to do something similar.
I like the fact that boost comes on sooooooo quick.
Those amr500 chargers look decently priced too. Where did ya source it?
Sent from my SM-J727T using Tapatalk
Turbo!
Mario sells the SC's on his website.
- MarioVelotta
If the throttle body is after the charger you then need to incorporate a blow-off valve to relative pressure like a turbo. Having the throttle body before the charger also helps to quite the noise.
I came up with a method that makes it pretty easy
[email protected]
[email protected]
- MarioVelotta
Swapped the clutch! I picked the B503 and a Stage 1.
Time to make BOOOOOOST again
[email protected]
[email protected]
- MarioVelotta
I haven't posted a video yet, here we go! Tuning needed but customer projects first
[email protected]
[email protected]
- buguy
Very nice!! I love videos!
Out of curiosity has anyone ran twin amr 500's?
Turbo!
Here we go
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Porsche piston squirters
30mm triple "O"ring pump
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
SL-1 Turbo prepped heads
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
- rubenski
Most times one asks for a twin blower setup, this comes up.
There is a vid on youtube too of that monster on a teststand
That thing is a beastrubenski wrote:Most times one asks for a twin blower setup, this comes up.
Turbo!
- petew
- rubenski
- rubenski
- petew
so what did he gain about 30 hp
