I would think that a fuel pump assembly from a flex fuel vehicle would be a great option, but also believe that most modern fuel pumps and FPRs are fine with E85.
Kenric
in tank fuel pump
- woodsbuggy1
Re: in tank fuel pump
Only one way to find out hahah.eanico wrote:Will the phantom fuel pump support E85 as is, meaning non-e85 kit?
Sent from my SM-N960U using Tapatalk
Turbo!
I went with the in tank pump kit for my efi build. Didnt like the ribbed tank top and thick rubber gasket to provide a good seal so I had a flange welded to the top of my tank to provide a flat surface and give it some strength.
- risk
Mine is in the same area but I did not weld on a flange. The thick gasket sealed off fine and I have not had any leaks. I do admire your setup and it looks nice and strong!
What sending unit are you planning on using? I currently have the stock beetle electronic style with the float arm turned sideways.. it only reads til the fuel level gets down in the sump area. So, less than 1/4 of a tank and I have to guess on my fuel level..
I had a new ww tank for my install so I decided to get the flange added as a precaution before it ever saw fuel in case it turned out that it leaked and I'd then need to weld on a used tank.
I'm planning on using the stock sender, it seems to clear everything OK but as yet its untested.
- xzener
My setup is very similar to yours Bapajo. I can confirm a stock sending unit works just fine.
Boost is contagious.
