Page 2 of 2
Re: Making my 72' standard handle....
Posted: Wed Jul 25, 2018 6:08 am
by vwo60
https://forums.aussieveedubbers.com/vie ... 861&page=9
This a 9 page post and therory about fiting a rack on a trailing arm front end, As I said I removed my narrowed baem and had a major improvement in handling and ride.
Posted: Wed Jul 25, 2018 8:00 am
by ChadH
andy198712 wrote: Wed Jul 25, 2018 1:41 am ..Is there a check for bump steer without driving it? I can mount it at what ever angle I want I think so can get this right now :)..
Check out this episode of Project Binky. No, It's not a beetle, but the concept should be the same. Move the suspension through it's whole arc, sans springs, and measure how much the steering angle changes throughout. Adjust tie rod heights and angles to minimize the changes.
How much this helps - I dunno? but Project Binky is cool! :P
https://www.youtube.com/watch?v=ob-FUF0Sh_E
Posted: Sat Jul 28, 2018 2:54 pm
by andy198712
I’ll have a play once the body is back on, just looking forward to actually driving it again now!
Posted: Mon Aug 13, 2018 7:32 am
by andy198712
if it helps my 4inch beam isnt actually 4inches narrowed.... i cut my leaves down two inches either side them dimpled, all exact as if it was 4inch narrowed....
when i come to fit the arms the leaves are too short!
So next set of leaves, then measured how far the dimples were out from a stock beams edge, then copied with on my new beam and hopefully this should be a perfect fit.
absolute text book "trust no one and measure twice" example here folks lol
its more like a 3inch narrowed beam!
Posted: Wed Aug 15, 2018 12:58 pm
by ps2375
Try the GAZ shocks, they are adjustable and very reasonably priced. For every day diving I have my fronts set at "0" and the rears at "7", out of 20 detents. For auto-x I had very good results with the FR at 8 and RR at 10. I drove it home with those settings and it was VERY stiff, i can't imagine going stiffer on them.
Posted: Fri Dec 11, 2020 10:52 pm
by UKLuke72
I know it's an old thread but I had my rear GAZ adjustables set to 10 clicks, drove nice.
Fitted the front, set to 10 clicks, about ripped my spine out of my nostrils.
Dropped the front to 3 clicks.
Handles a dream now.
Similar dilemma Andy.
I'm on 165/60 up front on a 4.5j rim, would like to band them out to 5.5/6" to get a 195 on but then would need to narrow it couple inches.
Potentially better keeping the 4.5j with stock width and HD arb?
Posted: Sat Dec 12, 2020 1:09 am
by Bruce2
UKLuke72 wrote: Fri Dec 11, 2020 10:52 pm I'm on 165/60 up front on a 4.5j rim, would like to band them out to 5.5/6" to get a 195 on but then would need to narrow it couple inches.
You wouldn't have to narrow the beam if you added the band to the inner half of the wheel.
Posted: Wed Dec 23, 2020 5:11 am
by UKLuke72
That's interesting.
Would be nice if that works out! I'll see if I can get some measurements.
Posted: Fri Feb 05, 2021 11:27 am
by chickensoup
you are referring to these right? https://gazcoilovers.com/vw-beetle-1200 ... 1364-p.asp
they look nice. and they seem to work for you guys. would you say they are better, the same, or worse than konis?
Posted: Sun Feb 07, 2021 11:39 am
by Bruce2
Those shocks are for K&L. They won't fit your 72.
Posted: Sun Mar 07, 2021 8:15 am
by GARRICK.CLARK1
My 67 bug has a 2 inch narrowed beam.
Drop spindles.
Discs and a wide 5 spacer.
2 x caster shims.
The copy BRM wheels and 145 tires are level with the wing edge with zero camber,
I cant get the front any lower like it is ,or the tire will touch. I might get some clearance if I put some camber into the front,
