Turbo EFI end pieces. OEM or CB
rubenski
Re: Turbo EFI end pieces. OEM or CB
Post by rubenski »
You forgot the first [ in your post!
Verstuurd vanaf mijn SM-A750FN met Tapatalk
Clonebug
Post by Clonebug »
It won't accept my Photobucket links anymore....it says " can't confirm image size" in red and won't post them.
It gives the link if I screw around a bit by copy and pasting but it don't work like it used to.....
Something must not have worked in the upgrade or move STF just did the other day.
buguy
Post by buguy »
Agreed. I have to log in tons of times now. Never used to have to do that.
andy198712
Post by andy198712 »
surely it depends where they seal?
is the O ring designed to seal AROUND the bore, or to be PRESSED onto the seat?
my manifolds (not CB) don't have a seat so guessing the O ring will seal AROUND the bore.... like an O ring is designed to do. yet my GSXR ITBs are square O rings and designed to be pressed onto a step.....
Krochus
Post by Krochus »
This is the first time I’ve been able to log in since posting.
Anyway the o ring like all ev1 injectors seats around the bore to seal.
The entry that had nothing to do with sealing is too deep to allow the injector o ring to reach its bore. No big deal an end mill will cure that.
"Anyway the o ring like all ev1 injectors seats around the bore to seal."
What said here is probably true but its not quite that simple as there are a lot of other features in the picture that come into play. (e.g., https://www.bing.com/search?q=design+pr ... 5ceed43557)
Krochus
Post by Krochus »
Don’t overthink this.
Now the injectors and o rings are able to seat as they should.
This was an injector body issue not an o ring one
buguy
Post by buguy »
Nice! That's how you get stuff done!
