Using an AMR500 in a 1915
grelland
Re: Using an AMR500 in a 1915
Post by grelland »
I bought mine used (or rather mounted; never run) for about $100; also the water/meth injection kit I got for about $150 so my build will be quite inexpensive, but then I have a lot of money into the ECU and EFI stuff already. Plus I fabricate most of the HW myself ;)
If you start out with a carbed engine with a distributor, you are looking at a significant cost.
V8Nate
Post by V8Nate »
I paid 160 for my amr and got lucky and found the turbo Saab vacuum can for 18 on ebay. Then roughly 15 bucks worth of hardware. Stock d/p intake, 034 dizzy, I already had a w/b o2. Ran a single kad but couldn't get it to run lean enough on cruise so ended up with a 60's Rochester from a straight 6, drilled the jet one size and the afr's were as perfect as you can expect for a carb I was really surprised.
Sent from my SM-N975U using Tapatalk
buguy
Post by buguy »
Nice... not bad. I bet the off idle torque is fun with one of those!
V8Nate
Post by V8Nate »
Very:)
