Page 2 of 2
Re: Thoughts on cam grind
Posted: Wed Nov 04, 2020 2:05 pm
by sixty5slug
It's a full size .68 a/r 60-1 billet wheel with 4" inlet (to4s compressor housing). Support up to 600hp.
How do you post pictures on this site? External web hosting/link?
Posted: Wed Nov 04, 2020 2:27 pm
by carsten bb
sixty5slug wrote: ↑Wed Nov 04, 2020 2:05 pm It's a full size .68 a/r 60-1 billet wheel with 4" inlet (to4s compressor housing). Support up to 600hp.
What size turbine wheel?
Posted: Wed Nov 04, 2020 3:21 pm
by madmike
Fk10 you'll thank me later :wink:
Posted: Wed Nov 04, 2020 4:41 pm
by sixty5slug
carsten bb wrote: ↑Wed Nov 04, 2020 2:27 pm
A T60-1 has a 60mm inducer and 76.2 Exducer (compressor)
Posted: Wed Nov 04, 2020 4:59 pm
by buguy
That's a big boy!
Posted: Wed Nov 04, 2020 11:10 pm
by carsten bb
sixty5slug wrote: ↑Wed Nov 04, 2020 4:41 pm
Hi, yes I know the 60-1. What I am asking is the size of the turbine (exhaust) wheel.
Posted: Thu Nov 05, 2020 6:41 am
by sixty5slug
Oh, it’s 62mm
Posted: Thu Nov 05, 2020 9:36 am
by sixty5slug
Clonebug wrote: ↑Wed Nov 04, 2020 10:27 am If you are running a Shag turbo you might be better off asking him which cam he would recommend.....
The cam did come from Shag. I'm mostly soliciting information from real world experience from folks who may have ran the EXR304 and/or the PTR1 from RLR in a similar combo. My last turbo motor had an FK8 which was fantastic. I'm building up my chassis to handle MUCH more power at this time. Won't be complete until mid to late next year projected.
Posted: Thu Nov 05, 2020 10:02 am
by Clonebug
Cam opinions are like ***holes......everyone has one. :wink: :wink:
It's interesting how many people on that other VW site can't make up their mind and end up buying 2-5 different cams before the build is even done and then leaving four of them on the shelf unused.
Smokey Unick said a specific cam is only perfect for a 300 rpm window....what 300 rpm window do you want it to be....was always the question.
I recommend getting his 3 book series and reading them.....especially the racing book.
That man packed 40 hours into a 24 hour day...........
My cam is boring...it's just a W-100.....
Posted: Fri Nov 06, 2020 3:42 am
by madmike
I'm stickin to my guns,I like Dave Kawells cam advice, fk8 for smallish motors and fk10 for the big ones :wink:
Posted: Fri Nov 06, 2020 1:05 pm
by panel
sixty5slug did you happen to read this ?
https://www.shoptalkforums.com/viewtopic.php?t=106178
Posted: Fri Nov 06, 2020 9:39 pm
by sixty5slug
panel wrote: ↑Fri Nov 06, 2020 1:05 pm sixty5slug did you happen to read this ?
Yeah, I’ve read through most of it. I’m going to run the SLR cam. Motor will be finished long before the chassis. So I’ll report the output after tuning it on paradise’s chassis dyno.
