Page 2 of 2
Re: new suspension, brakes for '69 Ghia
Posted: Mon Apr 19, 2021 11:01 pm
by Ian Godfrey
As you would know a Quaife weighs a ton, so that got some 'treatment' too
I drilled the clutch shaft and arm, and used the plastic throwout sleeve, took a bit out of the bowden guide etc.
Posted: Mon Apr 19, 2021 11:07 pm
by Ian Godfrey
The final result is I couldn't get the 5 speed down to the 4 speed weight but I got close, 5.7 higher
But it is a 5 speed with Quaife and bus output splines. I've got a ZF LSD, which is lighter, but I worry a bit about it breaking in a car heavier then a beetle.
Posted: Tue Apr 20, 2021 5:40 am
by H2OSB
Not bad at all.
H2OSB
Posted: Sun Apr 25, 2021 4:18 am
by Bruce2
Ian Godfrey wrote: ↑Mon Apr 19, 2021 11:01 pm
How long is the lever arm (center to center)?
Drilled cross shaft:
By my eye, you drilled it 3/8". My calculation says you've reduced the strength by only 5%. However, it is still 2.3 times stronger than the early 16mm shaft.
If you drilled it ½", its strength would be reduced by only 16%. And it would be a hair over double the strength of the early 16mm shaft (that never breaks).
Posted: Fri Apr 30, 2021 2:52 am
by Ian Godfrey
Bruce, the lever arm is 70mm centre to centre, and the minimum diameter of the clutch shaft is 19mm (where the circlips are).
I had drilled it to 10mm (3/8") but after thinking about what you said and looking at my graph, I drilled it out to 12mm
Probably still conservative with a stage 2 Kennedy which is not that heavy.
Posted: Mon Aug 16, 2021 1:23 am
by Ian Godfrey
I've been working steadily on the Ghia
cut open the pan for new fuel lines and to take some weight out
and put in harness mounts while I was in there
I got the Mendeola front end lined up, but it took a lot of work as my frame head was not in line with the centre of the pan
Welded in with some extra bracing
Posted: Mon Aug 16, 2021 2:37 am
by Ian Godfrey
on to the front suspension:
arms in
shocks, hubs (944) and disks (early 911)
steering rack, Golf 1 with a Quaife quick steer kit, also available in LHD
how it all looks
I was able to get 6 deg caster, and 0 - 4 neg camber as needed. I've gone for a 'crack' of toe in at this stage.
Posted: Mon Aug 16, 2021 2:43 am
by Ian Godfrey
these are the parts to support the spring plates (Elephant racing poly bronze bushes):
I've used uniballs (I think they are Rebel racing) on the trailing arms
and cut down the pivot bolt to fit
Torsion cover made out of 944 ends
Posted: Mon Aug 16, 2021 2:48 am
by Ian Godfrey
Rear arm first fit
With a disk, also early 911, with a few holes
sway bar on, (rebel racing, 'cut and shut' to suit VW)
and the caliper (UK wilwood for Ford Escort)
