Scat Volksracer crankshaft
woodsbuggy1
Re: Scat Volksracer crankshaft
Post by woodsbuggy1 »
Great, I called them last week about a 69mm counterweighted crank, they had several ready to go. Hope you get something figured out.
Coyotemutt
Post by Coyotemutt »
Due to quicker customer service I went with another CB Performance 4140 forged crank. Also, it dawned on me... the issues I've had are due to my own mistakes. If I just keep making the same building and tuning mistakes, more durable parts arent going to save me. I need to make sure to get every detail right. That's the only way it's going to survive.
madmike
Post by madmike »
so your going draw thru with a 4 barrel ?:lol: :lol:
gbaker770
Post by gbaker770 »
You are going to want to have the crank and flywheel balanced together anyway. Why not send the rods in to be checked as well. The bottom end assembly is crucial to any build.
Ive only used 3 engine builders over the past 30+ years (some of the best there is) and all 3 of them wouldn't even consider not doing this on every motor.
Coyotemutt
gbaker770 wrote: ↑Mon Feb 01, 2021 7:25 am You are going to want to have the crank and flywheel balanced together anyway. Why not send the rods in to be checked as well. The bottom end assembly is crucial to any build.
That's fair. I found another local shop I'm going to try. They say they can balance it without issue on the same machine they use for their water pumpers.
I'm taking my time rebuilding this time so theres no excuse not to have it checked out by a pro.
Its been a long time but as I remember balancing is not only the crank, flywheel and clutch assy but the rod and piston combinations also.
Coyotemutt
Ol'fogasaurus wrote: ↑Mon Feb 01, 2021 12:17 pm Its been a long time but as I remember balancing is not only the crank, flywheel and clutch assy but the rod and piston combinations also.
Yeah, but I can do the rods and pistons. Those are balanced statically.
Coyotemutt wrote: ↑Mon Feb 01, 2021 12:20 pm
You know but for those who don't know... it is often assumed having been done if the whole package isn't in the parts taken in for balancing. Just covering those who don't think about it.
gbaker770
Post by gbaker770 »
Exactly and blueprinted
gbaker770
Post by gbaker770 »
They guy that builds my motors now even goes way beyond that but thats a completely different topic.
