<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Pillow:
<B>Rex, I have seen that post before on Bus Boys, but never heard anyone with a finished product...
</B><HR></BLOCKQUOTE>
Adrian,
I have over 20K miles on my bus boys IRS II conversion on my '60 DC. Nice a beefy, I would never use a kit that utilizes the bug brake components. I went all the way and have brake/wheel components from a '79 bay on the DC.
Scott
IRS Conversion Kits
Pillow
IRS Conversion Kits
More updates
It LIVES! The 944 kit went on like butter! Everything fit perfectly from Old Speed (finally something "custom" I did not have to grind and reengineer
You do need the shorter VW Beetle rubber brake lines which was kind of odd to me at first. They are about 2" shorter than the stock bus lines.
You can use the 944 allen screw spindle nuts instead of the stock two nut and retainer washer setup.
For reference the wheels do not "sit-out" due to offset problems like some people were woried about.
The brake pedal effort is about the same as with the stock setup. Some think that with the bigger bay MC that the pedal effort would be high.
The bus brakes straight and true, no wobbles or pulling at all... It is perfect.
The only thing I need to get used to is the fatter tires (205/60/R15) that create more road contact and produce more feedback and wander on rutty pavement. The handling is definately better with alloys and performance tires over the flexy steel wheels and cheap tall sidewall 14" tires.
The only thing left to do is buy Bilstein shocks for the front end then it will be all set equipment wise. Also the brake pedal rod needs adjusted to takeup some free play in the engagement, then it is perfect.
Some people have asked how much it costs... Probably around $1000 when it is all said and done. This is with me being cheap too! This is counting wheels, tires, kit, MC, MC adapter, calipers, Old Speed stuff, and everything else to make it work.
Is the conversion worth it? Hell yah! Now I finally feel secure enough in its safety for my wife to drive the bus. Which is good, because some of the road trips we take are loooong and monotonous.
The next step is the rear IRS conversion. I plan on using either the Bus Boys IRS II style kit or the CSP kit from Europe (kind of like CSP better from the way Dave says it is setup). IRS T1 tranny with Thing flanges to run T4 CVs. The swing plates and all that will come from a early bay. The brakes will be bay drums modified for a Porsche pattern (Dave at CSP says in 2-3 months it will be available in ANY pattern you want). Also if that does not pan out Bus Boys can adapt the hubs and than I would have to weld and drill the late bay drums myself.
... Then there is the motor issue. I am so up in the air on this it is not even funny. It will be T1 based, but not sure what size. Torn between 1904 (74x90.5) or 1914 (69x94). But I have almost got everything for the CIS FI conversion though
($20!)
My end goal is to have a '66 bus that will kick modern SUVs buts!
Adrian Pillow
'66 VW Westfalia - "Biscuit"
'67 VW Deluxe Westfakia - "Dino"
'79 Porsche 911 SC - "Cochese"
).You do need the shorter VW Beetle rubber brake lines which was kind of odd to me at first. They are about 2" shorter than the stock bus lines.
($20!)My end goal is to have a '66 bus that will kick modern SUVs buts!
Adrian Pillow
- DaveB
IRS Conversion Kits
Pillow
You put 205/60/15's up front? Tou'er not lowered any right? Any chance of posting a list of parts needed for the 944 conversion? Also, what's CSP's webpage? I'm not familar with htem.
Dave
Dave
Single Cab
IRS Conversion Kits
Adrian,
Will CE be selling blank hubs AND drums or just blank hubs? What do the Bus Boys do to adapt the rear Bay hubs to get 5x130? Just drill for new studs?
Thomas
Thomas
Pillow
IRS Conversion Kits
Oops, meant to say CE for Creative Engineering: http://www.creative-engineering.com/cgi ... _store.cgi
The bus is stock height (and going to stay that way). The tires have good life left in them from the PO, so I will run them until they wear out. The Fuchs wheels are from a '76 911S and that is the normal size for the 911 front tire. This is definately not my first choice for tire sizes, but it works
I will hopefully be able to compile a list of goodies to do the conversion after I look at all my receipts to give accurate figures for anyone attempting the conversion.
Take Care,
Adrian Pillow
Take Care,
Adrian Pillow
Pillow
IRS Conversion Kits
Hey Thomas,
I have no idea what Bus Boys has to do to get the 130 pattern on the bay hubs? I kind of wondered how they could modify the hubs but yet could not modify drums? Seems like you could not do one w/o the other...
CE is planning to make new blank hubs in house and then get a German (OEM?) supplier to do the blank drums.
Adrian Pillow
Adrian Pillow
Single Cab
IRS Conversion Kits
I called the Bus Boys and was told that they aren't modifying Bay hubs. They directed me to FAT performance which was a bust. If all goes well I'm going to have a set done and try them out on my split.
Thomas
Thomas
