So if you really want a 90mm crank, I would run a 6" rod. Thats just me.
Marty Staggs
www.staggsracing.com
ROD RATIO ??
max, Der Bahnstormerz
ROD RATIO ??
If you're after maximum HP then you're going to need a 6.700" rod with a 90mm stroke crank
- dstar5000
Re: ROD RATIO ??
MASSIVE TYPE IV wrote: ↑Mon Oct 21, 2002 12:13 am Someone attempting a 90mm cranked engines should not need to ask these questions...this is gonna be interesting..
I shoot for 1.75 as well, as per the "Ricardo Rule"
DON
"Let me say it as simply as I can: transparency and the rule of law will be the touchstones
