Page 2 of 2
Posted: Thu Nov 06, 2003 5:21 am
by PJMS
roachghia70 wrote:are you implying that porsches are swingaxle cars? last time i checked everything since the 356 has had irs. even the "lowly" 914!
No I am not impling that Porche's are swing axle cars nor did I say that IRS could not work. What I did say was that IRS in "standard form" on the Bug was designed to make the car understeer more. Modifications to the IRS spec can produce improvements and I don't mean to imply that the IRS theory is somehow wrong; remember, Bugs are not Porche's.
I too drove both IRS and Swing Axle Bugs with torsion bar front suspension and my experience is the contrary. In North America, you had only one year of Swing Axle with the factory Z-bar, so much of the American experience never touched the late swing axle system. What the Z-bar did for the swing axle was to make it more neutral without the loss of positive handling. It is extremely difficult to make a Z-Bar swing axle lose traction, even on a wet road, when fitted with proper tires.
In respect of what Paul Illick said:
What Ralph Nader did for the American auto industry (or even the European) is consider by some to be a crime. In many respects, the effects of some of what he did was to take the responsibility away from the driver and put it solely with the manufacturer.
You are right about the relative costs of the systems but then VW had to do whatever they needed, to protect their market. It speaks volumes if the Buggy market was supplied by rolled Volkswagens, but somehow I doubt that is actually the whole truth. Ultimately, Nader undoubtedly caused the increase in cost of production of the vehicle and is, in part, responible for its demise in the 1970's. Something very similar befell Audi, when they were not the sole culprit. Politics?
Posted: Thu Nov 06, 2003 6:00 am
by roachghia70
i must have misunderstood your post that porsche would not stick with something that understeers and can not corner well. was that you? at work i have driven late model swing axle bugs with the z bar. i wouldn't want to own that rear suspension if i could own an irs car. i don't think that irs was designed to induce understeer, but rather to improve handling. remember handling and grip are two different things. for good handling you need a predictable suspension. a swingaxle will act different around different turns, making it less predictable than an irs. i have not had a z bar swingaxle in an extreme environment, but in driving it around town it seemed very similar to a regular swingaxle in this respect. if you can get good handling out of a long axle z bar suspension, then by all means do it and enjoy it. i think i will stick to the irs though. among other things, it's soooooooo much easier to change an axle!
Posted: Thu Nov 06, 2003 6:49 am
by PJMS
roachghia70 wrote:i must have misunderstood your post that porsche would not stick with something that understeers and can not corner well. was that you?
No, those two threads came from someone else but the earlier 'guest' entries were from me. So, sorry if I chewed off more than I should have! I hear what you say and agree with you that we should go in the direction that suits each of us best.
The Z-bar should only come into play at faster cornering or under heavy weight loads, so town driving should feel very similar to an earlier long axle, except that they have softer rear bars. These softer bars also increase understeer in these models. I do, however, think of traction as part of the whole handling package. For example, if you have a great IRS set up but use slicks in the wet, the handling will go in the ditch!
