head stud pattern
- Wally
I meant if you were to bore oversize...
Replating is still FAR cheaper vs a set of Nickies, in the odd case of it
being required. (sand)
There is also a place that sells a ceramic/nickel composite coating for bores...
google for it, I can't find the link, I swear I looked at it yesterday.
(SUPPOSEDLY better than Nicasil, sounds very similar)
They were based out of the UK, and had a US reseller IIRC.
- Wally
Hi guys,
This might become a bit off-topic, but whatever.
It is not really a wicked engine, because it will have the stock crank, a moderate street cam; only bigger jugs
; the really wicked engine is also in the works, but that takes a bit longer and is another story...
Your enthousiastm is inviting, so i have no problem of course to share my costs, but how can you judge if it is fair, cheap or expensive if you are at the other end of the world? I mean, there is hardly a world-wide market for these obsolete parts. But you may consider that yourself
I paid 300 euro's for six second hand piston/cylinders. I must say also that my machinist is doing the work in the evening in his own time, so he's not calculating me top dollar.
So far: case machined, cylinders machined and heads opened up: 100 euro's. Pistons still have to be machined, rods also (from 22 mm to 23 mm pin diameter) and the heads have to be machined for the right volume/clearence. Also spacers have to be made.
Well, one thing at the time.
Regards,
Walter
Regards,
Walter
- Wally
Good to hear you will be using those parts also.
Well, I don't want to discuss details yet, but yes I will use the porsche pistons. The domes will be machined to a certain, proven spec. This also keeps costs down a lot.
I just replied you.
Walter
I just replied you.
Walter
- Cam
Thanks for the info Wally. I'm looking at lots of options in regard to 100+mm B&P's and aircooled head options. Using Porsche parts seems like a perfect solution. Factory hi-po aircooled parts
300 Euro is about $500 Aus, so it would be about 600, landed here. Which is'nt too expensive when you look at the costs of LN nickies. Which will be getting near $4000 Aus
- Wally
You're welcome
Remember that a direct comparison to the ready and proven LN sets is not possible since you will have to add all the machine work, of which I have no exact idea how much that will be. I have only done a part of that yet.
Also this set-up (with the type 4 heads) has not (yet) been running in any aircooled configuration as far as I am aware!!
Therefore it is highly experimental for now, but great fun so far!
Greetings,
Walter
Greetings,
Walter
- Wally
Hi Kit,
How is that? The 964 p/c have a square stud pattern, so you can rotate all you want, but that won't make a difference...
Best regards,
Walter
Best regards,
Walter
Hi Walter
I owe you an appology.Yes the 964 barrell stud pattern is square.
I must have moved the barrel to get best fit (or so I thought).
Need to open head spigot bore to 113mm to centre barrel in chamber and try again.I dd notice that the offset T4 stud is almost outside of the cast finnage on the barrel.maybe if you proof machined the outside of the barrel at that point and slotted the other 3 stud holes is the best way to go?
kit
kit
- Wally
Hi Kit,
No need for that; we're here to help each other out with our hobby
Better take this discussion to the typ4rum tho, as this is not wbx related anymore. I openend a thread a few weeks ago with pictures of redrilled 964 jugs there.
Greetings,
Walter
Greetings,
Walter
