LIFTERS! The future looks promising! Maybe even rollers!
- Richie
- DudeAndHisBus
turboteener.
Guys, roller lifters are available now that will work with a T4. Go check out the Jesel Keyed roller lifters: www.jesel.com
They just require the use of a bronze bushing with a key way. You would have the block machined the same way you would with the standard lifter bushings.
The problem with using roller lifters is the lack of camshafts. The design will be radically different and the material will have to be billet. The price for the initial design will be fairly high.
Roller lifters will set you back about 800$ not including machine work and camshaft design.
The big issue here is the lack of a reliable, high quality, inexpensive stock style lifter. The Winston Cup boys are running 9600+ rpm all day long with flat tappets so don't look so quickly to the roller lifter as a solution. I am suprised no one has been using an aftermarket Chevy or Ford lifter instead of a stock lifter. There is much more aftermarket support for those motors. If Jake can bring a reliable replacement lifter to market I will very happy. I don't mind paying for ceramic lifters but I know lots of other people won't.
I don't know what the deal is with the Pauter stuff but I really haven't heard anything all that great about them. Obviously their Big Block is successful but little else seems worth all the hype.
76campmobile
Count me in as # 31 who is waiting for test results before doing a STOCK 2.0 rebuild. New #73 cam and matching $150 Two piece lifters (that I'm now afraid to use).
Damn! I'm ready to put the old factory lifters back in their same bores and take my chances with the cam going flat as opposed to having a 2pc lifter pushrod cup explode!!
The old stock lifters looked to be in pretty good shape I.E. no pitting or scoring whatsoever.
I would do the ceramics without a second thought if I had the $$ but I dont, so now what? Has anyone had ANY success with the 2pc "recommended" lifters???
I just want to get this thing finished to do some darn camping before the snow flys again!!
76campmobile
lowemp
Hold the press!!
Jake, we are currently planning on the ceramics in my 2615. Should I wait and see what these lifters and cam combos would add in my case? Time is not an issue at this point, obviously I just want the best combination you can produce.
Michael P. Lowe
Michael P. Lowe
lowemp
Excellent, and honestly the more I thought about it the ceramics made more sense. My brother is a ceramic engineer from Northwestern, and he was conviced I couldn't do better. Although, I took his opinion with a grain of salt since he currently works for intel making silicon chips.
On another topic, when you get mine together could I come out for the dyno testing? It would take a 2-3 week heads up but I want to see it in action.
Also I have a line on a proven Seqential FI intake plenum, but I can't give out the specifics in a public forum.
Michael P. Lowe
Michael P. Lowe
Hot Wheels
