As Marc stated in the original post above, if you can find a good DVDA advance/retard can for your distributor that costs less than a new SVDA, you can keep your present unit and just repair it. SVDA distributors have increased in price since this thread started (2004) but are still available from a variety of sources. John at aircooled.net has his own SVDA http://vwparts.aircooled.net/Aircooled- ... n-svda.htmscottioc wrote:OK I have a very similar problem. I have a 75 fuelie with dvda distributor. The canister has gone out, so the VW mechanic in my area set the timing to match an svda but now the thing overheats all the time. So, I'm not sure what to do here. Do I switch to an svda, buy a canister I'm at a loss.
works quite well and John stands behind his products (his unit utilizes his own curve / spring setup). Not the cheapest, but a quality unit for sure. Check around and read up on other peoples experiences.
