The ultimate cam/lifter proving ground!
Muffler Mike
Post by Muffler Mike »
That looks like a lot of work. But very cool.
Dig the four link, but the vice grips have to go. LOL.
the only thing i would think of is this might even be better if you could brake in the cam on the case you will use for that cam to compensate for tolerances in lifter bores.
but you might already be there too.
Post by MASSIVE TYPE IV »
Mike, I can swap cases to the case I will be using.. I made it universal..
The Vice grips were an added option :shock:
I can also use a Type I case and test Type I lifters... Then I really will make some people mad!
Muffler Mike
MASSIVE TYPE IV wrote: I can also use a Type I case and test Type I lifters... Then I really will make some people mad!
LOL
keep up the great work.
Thanks man... Keep up the good driving!
NO_H2O
Post by NO_H2O »
That came out sweet Jake. Cool to see it finished. Did you make a welder out of Chad.
Plastermaster
Post by Plastermaster »
I never ( or have forgotten) seen the Massive logo on your engines. That looks sharp on your valve covers and shroud. Way more class than alot of other aftermarket VW stuff.
Ron
davidcardone
Post by davidcardone »
Jake, can I send my cam and lifters to you to be run on the machine? Is that a service you plan to offer?
David
David, Yes you can...The service is 125.00 for an 8 hour cycle.. If it fails I'll send you back the pieces!
Guest
Post by Guest »
Jake, $125 is $125, but it's CHEAP insurance. I bought a Webcam 163 with Web lifters from a guy that built a motor and then tore it down. He ran it for what he estimates was about 10 hours or so. The lobes and the lifters look (to me) fine, but I'm still skeptical based on all I've read. Will send them to you this week. What's the turnaround time you estimate?
Locked
