Testing underway - AWESOME new Engine management system
- Brian Murray
- Kafer_Mike
Jake, have you played with one of the MegaSquirt EMS's? Seems like a lot of the T1 guys (especially the turbo crowd) are going that route. If so, how does it compare to Dave's? Where would you estimate the cost of his entire EMS system vs. a traditional carb set-up?
"Build 'em fast...or let 'em sit"
- Tom Notch
Hmmmm, never seen a modern EFI brain that wasn't solid state. Glad there's another to chose from.
MASSIVE TYPE IV wrote:Thats the reason i have stayed away from EFI for so many years.... With this system there is nothing to break, its all solid state.....
Tom
Tom's Old VW Home
DVKK
DSD, dark side disciples
Tom's Old VW Home
DVKK
- jonas_linder
- speedy57tub
Darn Jake,
I am impressed! Like how this "close-loop" EFI system is producing almost linear HP and Torque outputs while having a very predictble and smooth fuel consumption plot. It would be very easy to figure out your gearing given this type of data. This data does say something about the carburation in that the jetting transitions from idle all the way up to the higher RPM range is limiting the engines full output capabilities. It pays to really look at the fuel consumption differentials so you can optimize the jetting on this engine combo as best as it can be done. Jake, Besides the usual close-loop TPS, CHT, RPM, and 02 inputs, how many other feedback sensors does the system use? Looks like you can use some electronic packaging--go with an EMI reduction enclosure, they usually are better at also insulating the components from heat. Heat sinks can be mounted onto the exterior of the box without physically penetrating the enclosure envelope thus allowing it to be moisture/water-proof). A a fan can also be employed to dissipate the heat and keep the electronics cooler.
Oh yeah, is the fork also part of the system? LOL... KEEP UP THE GREAT WORK GUYS!
- Brian Murray
- speedy57tub
KitCarlson EMS Turbo
A MAP sensor capable of 36.3 PSI is used for the Turbo unit. The MAP timing table also advances or retards timing as desired.
One unit is already in the field on a 2.0L Turbo 914.
- davygrvy
megasquirt is rather limited. I don't believe it is a closed-loop system and works under batch mode injection rather than sequential. Nor does it do ignition. It was also written in linear assembly which is difficult to modify for the hobbiest (speaking for myself).jonas_linder wrote:megasquirt is cool, you should test it !
Again, speaking for myself, I would be much happier with something interrupt-based and written in a managable language such as C. That is if the source was "open".
