Are the headstuds going to be relocated so they are more symetrical (square instead of rectangular), like the type I? It seems like they would be more turbo friendly if they were.
One set of my heads will be a 100% replacement for stock, the others will be set up to run a special set of encapsulated stud Nickies and a different head sealing method.
MASSIVE TYPE IV wrote:Yep, maybe... BUT the expansion rates are different than a Type I due to the materials that comprise the TI.
The 356 had equal length studs, and used a sunken lower boss that allowed it to work with special nuts.
These use a custom nut type deal. The expansion rate of the head itself should not be an issue. If the studs are the same length, the clamping loads are equal.
Jake: "One set of my heads will be a 100% replacement for stock."
I imagine there will be a ton of demand for these!
I'll sign up as soon as you have them or prepay...
Jos
