Hints for setting up carb linkage
paul_f
That engine had a cheapo linkage on it not a CB one..
So I need to order something so I can fix this problem, we have a CB agent in this country who has a few bits and pieces.
What do I need to ask him for:
baseplates - from which linkage kit?
extension piece?
The rest of the kit will be fine
Paul
extension piece?
Paul
paul_f
Fran Hebert
Jake,
How close are you to finishing & perfecting your design of the "BELLCRANK SYSTEM" ? I like the idea of eliminating the hex bar and incorperating the bellcrank instead on your turn key motors. It not only sounds like it would work more proficiently but would also make the massIVe set up more streamlined & less cluttered.
Fran
Fran
- davygrvy
Exactly! I agree. I made some new adapter plates today. I just have to decide where to drill the holes for the pivots.MASSIVE TYPE IV wrote:Also ensure that the arms of the linkage that come off the hex bar are an equal distance away from the center of the velocity stacks. If one is further in, or out the ratio of opening will be accelerated on one side..
drill the holes for the pivots the same in each adaptor but don't drill the holes that mount them to the air filter base yet on one side!
Use vice grips to clamp one side on after the other side is drilled and bolted. Then when you find the sweet spot on the side that was clamped drill a pilot hole through the air filter base and into the adaptor!
This will get it perfect.
- Plastermaster
I am running AJ Sims linkage which is based on the scat bellcrank style. It took a little modification to really get it dialed in, but It works nicely with the Dells. There is a set up process to get it to open up the whole way, and the linckage arms moving at the same rate etc. I had to drill a little slop in the connection to the throttle to allow for engine expansion. When the engine warms up the carbs move further apart. The linkage arms stay the same length resulting in the idle speed increasing. It is a touchy adjustment because too much slop causes 1 carb to open just a tad before the other one. Once it is dialed in it works great. I would prefer a linkage that pulls from one end and 1 solid arm or cable between the 2 carbs like when they are used on the V8s. It could probably be done but the throttle cable would need to enter the engine bay at a different location.
Ron
Ron
- davygrvy
Darn, I drilled the holes for the base first. I like your method better. I'll try again monday with a fresh pair. Thanks.MASSIVE TYPE IV wrote:drill the holes for the pivots the same in each adaptor but don't drill the holes that mount them to the air filter base yet on one side!
