DTM and "under cylinder tins", are they fully need
Wally
Post by Wally »
Well E, you have a type 4, so you can just slide the pushrods tubes out without unbolting the head and fit the missing tin.
Finally you can take full advantage of this fantastic type 4 feature! :wink:
Don't you feel happy now ? :twisted: :lol:
Have fun!
Walter
Ephry73
Post by Ephry73 »
YUP! :D
When I was running my 1700cc with the "Cali" conversion, I was running the type 4 under cylinder tins. Seem to work ok. I tried to modify them a bit by opening the outer ends more, not sure if it helped or hurt the setup.
Will definitely install the type 1 ones under the cylinders.
Ephry
P.S. Wally, let us know about the 2.4
Post by MASSIVE TYPE IV »
Anything will work "OK"... But why not make it as good as possible???
Developments are made to be used!
Ephry73
Post by Ephry73 »
Hence why l'm using the type 1 tins now.
Oh, almost forgot, I was able to use the preasure sender with the DTM in the stock location(VDO dual sender Oil preasure/oil light). tight fit, but it fits just fine.
Ephry
Wally
Post by Wally »
As promised:
As you see, I just sqeezed the edges flat. Removing them would have been neater tho...
Also, the part under the head I cut off in order to resemble it more as the type 1 tin.
Here are they installed under the cylinders:
It's not nicely coated, but clean and I _may_ want to adjust it some more :roll:
Greetings,
Walter
Ephry73
Post by Ephry73 »
Hey Wally, thanks. I was thinking of snipping the outer "ears" ff the stock type 4 tins and bending the middle "diverters" down, to replicate the type 1 setup. Never got around to do it.
Sure looks sweet.
Jake, so type 1 tin under the cylinder on the head side? Again, thanks
Ephry
mikey373
Post by mikey373 »
Hey Wally.........what kind of cylinders are those???? Are they 911 with redrilled holes??
Wally
Post by Wally »
Yes, they are.
964 Nikasils with a 100mm bore. There is an old thread where I have explained the use of those in more detail.
Regards,
Walter
Dominic
Type 1 under Cylinder tins ?
Post by Dominic »
Can someone post a picture of the type 1 under cylinder tin ?
Will the type 1 tins also help cooling with the stock t-4 cooling set up?
Thanks in advance.
Dominic
Kep the stock tins if you have a STOCK TIV cooling system. It was designed with them....
Pooter
Post by Pooter »
Off topic: where do you guys measure CHT? plug 3, or head stud near #3?
ONLY Under a spark plug... Do a search I have written volumes on the subject and have directly tested different areas and shared the findings..
Locked
