www.apfelbeck.nl
- Wally
Ah, see what you mean there Jake. The sideway clearence is what I meant originally.
Don't think the cam drive has been test fitted already, but he has made an intermediate axis for the left bank, so clearence for that left bank would be enough probably
Time will tell.
Greetings,
Walter
Time will tell.
Greetings,
Walter
cidarfritz
actually, you are not really changing the subject-zctv2 wrote:I hate to change the subject but if you get the heads perfected for the type 4 will you consider development for a type one.
Ludwig Apfelbeck designed a Type 1 head first.
He is writing about some hillclimb racing with this engine.
Maybe he was "overtaken" by Formula Super Vee
before doing much with that.
Apfelbeck's book is still available on Amazon.
- dstar
YES, if you have the $30,000 necessary to PAY for it.......
NOT to even MENTION, the maintenance on it.....
Jake, don't give up on your heads
The VAST majority of Type 4 enthusiasts won't even be able to afford to DREAM about heads like that.
We need heads for around $1000 each, that will take a 2L to 8K, won't overheat doing it and make POWER.
Don
Don
cidarfritz
Apfelbeck heads are definitely a gem-dstar wrote:YES, if you have the $30,000 necessary to PAY for it.......
Jake, don't give up on your heads![]()
The VAST majority of Type 4 enthusiasts won't even be able to afford to DREAM about heads like that.![]()
Don
and there's a whole world between stock Transporter heads and ohc.
IMO Type1- or 356 style heads, 356 for the angled exhaust valve position,
will do a good job for a street car.
there's still a big questionmark behind Apfelbeck-
where and how to get rid of the heat off that massive piece of an aluminium head ?
Will this at the end limit those heads to an application for quartermile racing only?
Apfelbeck, btw. would be someone for some tough discussion with Jake Raby.
If i have understood his book just very little,
he was pleading for an ideal of a completely closed cooling jacket
for every cylinder and head- which he accepted to be impossible though.
Jake, if I remember an earlier posting right, just leaves away the under-cylinder tin.
Now please don’t get confused neither of you, both go ahead!
Good luck to both of you!
