I WAS!platform115 wrote:Oh yeah, and I wasn't serious about wacking the carb.. hehe
Don
That is great man. What rpm did you idle at?The carb ran smooth as silk on my engine, but again, will require
very SLIGHT adjustments when you get it.
Hopefully you have time to give me a run down of what all it took sometime.Folks, these carbs WILL work, it just takes a LOT of work and tuning
to MAKE them work!
wow... I can't even imagine a smooth idle at 800rpm...I set the idle at 800 ...
Man... you shoulda seen the engine this puppy came off of!!It just took CLEANING! BUWAHAHAHAHAHAHAHAHAHAAHHA!
Man that was the nastiest crab I have ever came across!
Yes, I've got the gauge, so that shouldn't be a problem.You will still need to set idle on it when you install it. Set your fuel
pressure at 2.5 - 3PSI also....
