SDS throttle body
Tom Notch
Post by Tom Notch »
I've been running a 55mm, at least I think it was 55 when I found it in a junkyard. Dang CRS! its off a 2.8 or 3.0 GM V6. Mine likes to pull past 6200 but I shift at 5800-6000 when I'm pushing it and the limiter is set at 6300 now.
Tom
Tom's Old VW Home
DVKK
DSD, dark side disciples
lowemp
Post by lowemp »
Tom, thanks for the input.
Jake, this may get more simple than I thought.
I have been looking at the stock 2.0 intake plenum and runners.
each runner is 39cm long and has a volume of 390 cc
the plenum is roughly the same size as the one Charles sent me, 1800cc
There is room along the #1 runner to attach a 70mm pipe and fit the TB.
Then all I need to do is seal up the original TB port in the top. This also would route the intake air in the proper direction to attach it to the rear apron.
Charles runners were 30cm long with a 1800cc plenum.
Would the extra 9cm of runner length hurt this engine which I don't plan to rev past 6000?
Would the extra length help low end torque?
It seems that the stock plenum may meet my needs.
What do you think?
Michael
lowemp
Post by lowemp »
Jake,
I am available if you have time to talk tonight. I have the parts for the plenum all over my desk trying to estimate volumes.
Locked
