New Linkage for the TIV DTM- Its bellcrank!
paul_f
Post by paul_f »
Oh and I just checked, there may be 3/4" of room between the cooler and the top of the engine bay, its difficult to measure - however a piece of wood I had which was 13/16" did not fit - I wonder if its possible to remove 1mm of the cooler housing here though
danielzink
Post by danielzink »
what did you do at the carb throttle end - make up a spacer the side between the throttle bar and the
Like this ?
Dan
65 Notch 2300cc Type4
EJ22 powered Rail
http://www.danielzink.com
Locked
