Spec 'B' trans
Sixty3GL
Post by Sixty3GL »
Thanks for the replies :D
davygrvy
Post by davygrvy »
marekv8 wrote:Jake added a Quaife LSD and I would highly recommend it for your swing axle
If you're into power slides... A quaife rules :) There's nothing like it. very controlable.
Plastermaster
Post by Plastermaster »
And just where have you been hiding? :)
Good to see ya!
Ron
davygrvy
Post by davygrvy »
kinda still hiding, though. The car is apart in the garage.. I haven't finished it yet.. It'll happen.. don't rush me :)
huw'sspeedster
Post by huw'sspeedster »
Jake in the section on your cars you said that you had fitted sway away hd axels to the plague!Have you removed them in favor of stock?
Post by MASSIVE TYPE IV »
I have 3 gearboxes for the car........each are complete with axles and only one has the H/D axles.
huw'sspeedster
Why 3? different ratios or stengths or just testing different bits is it ?
All different ratios for different engines/combos- it's a full time test car.
Sixty3GL
Post by Sixty3GL »
I just placed my order, after a few extra weeks of saving my pennies :D
Cool... We sold 4 trannys over the weekend and I think we are out of Swing Axles at this point... We should have one for you in about a week, as soon as we get the next batch completed.
**correction**
We DO have one Swing axle B spec tranny IN STOCK.. It will leave here today!
Sixty3GL
Post by Sixty3GL »
:shock: :D
Sweet, sounds good to me.
Sixty3GL
Post by Sixty3GL »
I've been reading through some posts about super diffs., and it got me wondering if Jake's trannies come with spider gears installed?
Also, what exactly comes with the transmission from Jake? I know it has case, grears, side covers. What about nose cone? Thanks for your help :!:
Nose cone included. IRS versions have CV flanges installed. Swing units have the diff installed, ready for the customer's axles from their old tranny.
All units are sold with differentials installed.
All "B" gear boxes come with super diffs.
Also, all B gearboxes also have cryoed shift forks and differential components.
Sixty3GL
Post by Sixty3GL »
Cool, thanks again for the information. here is a pic. of the 2376 (44IDF, stock cam, stage 2 P/P, 44intake/ 38 exhaust) with original DTM, that will be hooked up to my new trans...
http://img.photobucket.com/albums/v342/ ... 0_0172.jpg
Locked
