Re: Chris/Marc's project
Posted: Sat Apr 20, 2013 7:36 am
The Beetle has been on the road for a year now, and really hasn't missed a beat mechanically, thankfully - still haven't changed the caliper bolt that I had to acquire during my first test-drive
...Last little tune-up revealed about 20% more throttle as the Bowden tube must have finally found 'home' at one point...and I picked-up some Wolfsburg West replacement headlight buckets - much better fit/finish than the Rossi's - Which main problem seems to be rusting and lack of decent adjustability - and the passenger fiberglass fender needs the (re-pop OEM) range to keep from lighting up the trees
The 16" front tires will need replacement in the fall, they've been on the rims since I was in HS.
The 964 5-spoke 16x8's (w/195/50's up front and 215/40's on back) really look better on the Corrado...My buddy has ran with so much excessive negative camber the 195's they'll be replaced soon for another pair of 215/40's likely. Doing an E-code headlight conversion w/custom wiring harness to H4's next.
