Seabee turbo buggy build
Turbo_Manx_Maniac
Post by Turbo_Manx_Maniac »
zancat wrote:
Turbo_Manx_Maniac wrote:I just bought a 2M radio and am looking at intercomms.
My brother has his license and I am thinking about getting one too. He has a 2M setup in Ocotillo Wells. His call sign is KD6RSQ.
Zancat
Maybe you can find out what freq he uses and I'll give him a shout when I'm out there.
Are you thinking base or mobile?
I accidentally Googled my Twitter. (And I liked it)
seabeebuggy
Post by seabeebuggy »
Mine is KI6FWZ. Hams are way better than CB's
www.BigMikesGuns.com oe https://www.BMGAA.com
Thomas Jefferson said It may be necessary for a country to have a revolution every 200 years to right the wrongs of a Government.
Got Lead?
seabeebuggy
Replacing all the fuel line today. new steel line for the cab area. and Fi hose line. Last fuel line is falling apart.
seabeebuggy wrote:Keeping my to do list up to date
seabeebuggy wrote:OK the list keeps growing. I guess it would be a good thing to do more than once every year.
1 Swap out shocks and spring plates. DONE
2. CV's need repacking (bolts started to come loose. DONE
3.CV boot leaking DONE
4. Intercooler fan is not getting power.
5. wire light to fan
6 Alt light is not getting the ground (bad wire) Dummy me. it was the oil wire not the alt. wire fell off sender. FIXED
7. Fuel line is leaking , May need to replace all 40' of it. Not going to be fun. Replacing all if it now. some steel and high quality fuel line this time. DONE
8. Install new intercom system. Done
9 Install head phone hanger. DONE
10 Wire in larger lights for the ALT and OIL lights. DONE
11. Fix Head light (keep from turning all the time) Update, Fiberglass busted under light, I will have to re glass the mount. :evil: DONE
12. Repair/ Replace dimer switch. DONE
13 Add slave saver ( NOT Obama ) trans kind. DONE
14. Work on A-arms. I need to adjust the camber . DONE
15. Adjust 1900's drum brakes in front. DONE
16 Weld shock mounts and limit strap mounts. DONE
17 Fix Alki tank Leaking at fitting. DONE
18. Fix skid plate
19. Weld muffler tab . Hard time figuring this one out, want it to look good and yet be easy to remove pipe for the street use muffler.
20. Turbo oil leak
21. Paint mirrors and brackets DONE
22Weld on new windshield mount tabs. DONE
23.Align front , DONE and back tires.
24. Weld broken pan tabs on the rear.
25. Fix BOV problem Broke it , ordered new BOV
26. Fix Alki pressure switch. WORKING
27. Repair roof rack cover. DONE
28. fix carb that is dumping fuel in the engine by the gallons.
29 change oil.
30. re jet carbs for CA.
31. speed sensor tab needs welded on. , wire to speedo
32. Replace All vacuum lines.
3. :shock: I need a nap.
Got Lead?
seabeebuggy
Because I love posting here i will offer 4 more photos of useless info. :lol:
headlight fixed. glassed up strong. wheels aligned. you can see the old school way of doing it. lines on the tires.
made some changes to my extinguisher
leather you can use this . I am out of ammo.
back up in case I need it.
Got Lead?
Seabee, outstanding improvements you have made, buggy is looking good. Thanks for the use of the sticker.
seabeebuggy
WHY? WHY? WHY? !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
It just never freaking ends!!!!!!!!!!!
My car would not start and i go back to look and there is fuel every where. I was coming out the exhaust.
my carb on one side must have a stuck float. I must have run it almost dry after replacing the fuel lines. all the air in the lines while running...?
Now I need to take it off and un stick it I may need to adjust the total down tab to keep it from going to far down.
Got Lead?
seabeebuggy
I have not even driven the car yet, I have adjusted the limit straps 3 times. Just from being on the stands. I ordered 24'' straps. I need 23 or 22 really. I hope I don't use up all the adjuster before I get out to play.
I will be adding the speed ring from zancat. thanks!
I have about 5 after work nights to complete everything. leaving the weekend to work on the rear alignment. in the sand there is no need for perfection but on the road i want it good. Don't want to replace 400$ in tires too soon.
Got Lead?
Getrdone
Post by Getrdone »
You should'nt get that close with your exhaust is probably the problem :shock:
seabeebuggy
??? get what close????
Got Lead?
fusername
Post by fusername »
I'm glad someone got to that before me, I have racked up enough stupid posts this week. :roll:
Turbo_Manx_Maniac
seabeebuggy wrote:WHY? WHY? WHY? !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
This is what they mean. Really Seabee, how exactly are you tuning this car? No wonder your floats are sticky.
Let it never be said I was afraid to post another stupid post.
seabeebuggy
I was at work when I read that, I was laughing really hard.. I guess i missed a letter there. NOT I but IT.
Got Lead?
seabeebuggy
seabeebuggy wrote:Replacing all the fuel line today. new steel line for the cab area. and Fi hose line. Last fuel line is falling apart.
3.CV boot leaking , Boot will not stay on.
4. Intercooler fan is not getting power DONE.
18. Fix skid plate
19. Weld muffler tab . Hard time figuring this one out, want it to look good and yet be easy to remove pipe for the street use muffler. DONE
20. Turbo oil leak
25. Fix BOV problem Broke it , ordered new BOV DONE
28. fix carb that is dumping fuel in the engine by the gallons DONE.
29 change oil.
32. Replace All vacuum lines DONE.
Got Lead?
seabeebuggy
OK that is it. I am starting all over. Here it is.
Got Lead?
takotruckin
Post by takotruckin »
HUH? You're gonna turbo the blazer?
