2270cc type 4 EFI Turbo: my first engine build
split1950
Re: 2270cc type 4 EFI Turbo: my first engine build
Post by split1950 »
I did think about it but I don't want to strip it again later to paint it.
buguy
Post by buguy »
Do you have a color picked out?
split1950
Post by split1950 »
I'm going back to stock so L11 pastel Green
buguy
Post by buguy »
That will look great! Single stage or base/clear?
split1950
Post by split1950 »
Base and clear. I have a Lenny Copp interior too a real sleeper.......
buguy
Post by buguy »
Nice!
split1950
Post by split1950 »
I've been thinking a lot about my engine breather system now I'm at final mockup stage.
To recap:
Dry sump 2 stage pump
I have 3 breathers, 1 below the 911 fan (would have been the original breather tower) + 1 on each cylinder head.
I assume (but would like to hear from people with experience);
I connect those 3 breathers to a small say <1 litre breather box, the breather box has a small air filter on it. This box needs to be higher than the oil tank, the lines have no droop to pool oil in effectively blocking them.
The bottom of the breather box goes into the top of the dry sump tank
The dry sump tank top is vented via a small air filter
Is it correct / going to work?
What I'm trying to do is to avoid remaking this system on a painted car after oil goes out everywhere.....
madmike
Post by madmike »
I would go with a 1 1/2 at least if ya have the space? biggest hoses too :wink:
woodsbuggy1
Post by woodsbuggy1 »
Very nice build you have going. My experience is only with type1 platform so may not apply, but my offroad car with a 2276 and dry sump is vented to a 1 liter breather box with filter and all lines run uphill to breather box, a 1/2" from each case half and 1 to dry sump tank. I do not vent the valve covers, have seen videos of how much oil they contain when this happens. I want the oil to return to the case so I make it the vented area.
Good Luck
Kenric
buguy
Post by buguy »
I have read the same. Venting the valve covers causes the oil not to return to the case.
split1950
Post by split1950 »
I've been working hard the last 2 months to get this on the road this year
New and improved chargecooler design (now welded, no pics to hand)
Front mounted oil cooler with fans and my brackets
Next task is to mount my custom dry sump oil tank under the package tray
rubenski
Post by rubenski »
Amazing work!
Verstuurd vanaf mijn SM-A515F met Tapatalk
madmike
Post by madmike »
Busy like a beaver :wink: looks great !
split1950
Post by split1950 »
One of the hardest tasks was the pressure hats - I bought "blanks" from CB as I'm using 57mm tube and wanted to set the inlet positions for my application. I had to weld 2 hole saws together to get the drilling depth at the angle I needed.
Then I had to use a handheld power drill, it was sketchy!
Of course the bases don't work with my 50mm throttle bodies so then there's stuff like this.....
Then there's all the other non engine stuff that goes with a big build like this (5 speed shifter, suspension, machining hubs, brakes, ....) limited by the fact I can't cut the body at all to do this (as it's a '50)
Wally
Post by Wally »
Awesome fabrication!
I actually don’t think you will ever need the fans on thé oil cooler with the cooler in that spot and in that size.
