200hp 1200DP Turbo 'Challenger motor'
- Dan Dryden
Re: 1200 Turbo EFI build 'Challenger motor'
Any updates for us Wally?
- brewsy
Sorry, I'm a lurker
so dont think I should be poking a 'maker' like you Wally but there are tons of people waiting to see and hear this awesome little 1200 machine roar into life...
Please put us out of our misery!!
On another note, Dan Dryden ex of The Mill?? never knew you were into Beetles mate. This is Brewster now in NYCB
- Wally
Cheers fellas,
Unfortunately I just found out last week that the engine had such low dynamic compression that it would start. Not sure if it was the hot camshaft in combination with the already low compression that caused that of too much honing the barrels?
Anyways, with the short time remaining I decided to take this on pragmatic and have the heads fly-cut some more to gain more conpression.
Heads are done end of this week and then I'll surely need some reassembling time before I can try again.
Fingers crossed,
Walter
Fingers crossed,
Walter
- MarioVelotta
Oh bummer, did you check compression while cranking? How low was it?
[email protected]
[email protected]
70dragbug
Last years cam was even hotter wasn 't it? Maybe too much lift (ratio rockers) and the airspeed just collapses? Flycutting the heads should help or install smaller rockers? Hope you get it sorted out mate! Must be a real pain removing all that plumbing.....I feel for ya;)
Mark
Mark
- Dan Dryden
That sucks Wally.
I hope the re-assembly isn't too much of a PITA.
Hey, sorry Brewster I think you got the wrong Dan Dryden. Welcome to the forum though.brewsy wrote:On another note, Dan Dryden ex of The Mill?? never knew you were into Beetles mate. This is Brewster now in NYCB
- brewsy
- Wally
It finally runs after installing a new set of AA piston and cylinders (the only quick solution and fingers crossed they hold). Considering I am using 60lbs injectors and K8 kinda cam on a 1192cc engine, it runs sort-of ok-ish at idle at this first time it has warmed up its 7 liters of oil.
About time too, as next week this time its on route to a WOT pass at an airfield in England.
- juki48
awesome. would love too hear a little more rpm's! I've been considering a similar intercooler placement on my ghia, sort of a duck tail intercooler/spoiler.
andy198712
Sounds smooth mate!
Enjoy the trip to the uk, hope the weather holds for you!
- Wally
Cheers Andy. With the header fully bolted on afterwards, it was a lot quieter stillandy198712 wrote:Sounds smooth mate!
Last friday just before the EL2K13 weekend, I made the maiden testdrive and pushed untill the first wastegate openend (0.7 bar). The boost pressure rose very smoothly further to about 1.1 bar or 16 psi from the second turbo and then the engine seized...
I gambled for time reasons and installed a stock AA 1200 cc piston set. I just hadn't time to have the barrels clearenced properly for tuning use and it bit me hard. Engine dissection will tell if that was really the main reason but it sure sounded and felt like that. Its all in the game though, so I'll take my loss
So it meant I couldn't run at Elvington myself, but we went anyways with my DD and were very motivated to come back with a strong engine in the next year(s).
This also means I will abandon the 1200 Challenge and this engine (type 1) set-up. Decided to build-up a type 4 turbo again from parts I already have, sell the type 1 parts and see if I can enter the Speed trials next year.
- Kalle
Ahh.. FINALLY! Back to business and stop playing around with those mouse engines. They are just a waste of time and money.......................................................................................................................................................................................................................... coming from the guy with a 1641ccmWally wrote:andy198712 wrote:Sounds smooth mate!
-BB-
- Wally
Yeah, I'am afraid so Kalle. It was great fun and a good (learning) experience, but eventually not very fun to drive tbh: my Porsche G50 gearbox is really not intended for the very low sub 3K torque of a 1,2ltr engine with a turbo cam and I really want to DRIVE again.
andy198712
thats a pisser mate! but as you say, thats part of it!Wally wrote:Cheers Andy. With the header fully bolted on afterwards, it was a lot quieter stillandy198712 wrote:Sounds smooth mate!
Enjoy the trip to the uk, hope the weather holds for you!![]()
Last friday just before the EL2K13 weekend, I made the maiden testdrive and pushed untill the first wastegate openend (0.7 bar). The boost pressure rose very smoothly further to about 1.1 bar or 16 psi from the second turbo and then the engine seized...![]()
best of luck with the T4 turbo! will keep an eye on that thread, i'll keep an eye on your for sale thread too when it comes up
- Chip Birks
I got Burly's email today and was heartbroken to hear about your engine mishap. Sad to see that happen!
Good luck on the new venture! I can't wait to see what you come up with next!
