I'd love to tell you how I got on.... but my iphone has died, and using a camera is plain hard work.
I did think about a roller tube guys, but the angle of attack was all wrong, meaning that the direction of pull would mean I couldn't get full throttle because I'd be pulling downwards when I needed to pull straight backwards towards the fan shroud.
Shame really, I've ended up by drilling another hole in the shroud, 3 or 4 inches directly above the original and inserting a swan neck shaped fuel pipe. ( Do you have swans in America? shure you do
) So it now pullls at the right angle but there's a bit too much drag on it. I think long term I'll be welding a tube for the dump valve, directly onto the top of the chargecooler.. thus dropping the throttlebody by 3 or 4 inches.... roller throttle would work a treat then.
A good day today
I've just about assembled everything, positioned and fitted all my breather pipes, fuel pipes with sexy new alloy AN6 fittings.
Tomorrow I've got a website to build... which gets in the way a bit
Then I've got to come up with a fuel pump block off, top the oil up and then see if she'll start. The map could be miles out - so I've wound my MBC down to nothing - but I won't be doing much until I get it back on the rollers next week ( remind me to book it in)
Last job will be to try and fabricate some kind of heat protection from a few bits of used heat shielding from a Ford mondeo I get off ebay.
Budget has come to an abrupt halt.
