Page 18 of 19
Re: Problem of the day. Post it up!
Posted: Tue May 03, 2016 4:27 am
by madmike
So true, just to freak out the 'Chevy' boys :lol: :lol: :lol:
Posted: Sat Jun 11, 2016 2:30 am
by MAA
Quick question I haven't been able to find the answer on here. Where are you guys getting your oil input line from?
Posted: Sat Jun 11, 2016 3:44 am
by madmike
I use a -3 stainless steel brake line screwed into a T on the case, where the stock oil sender is :wink:
Posted: Tue Jul 19, 2016 4:32 am
by madmike
It was the 'Wastegate ' giving me grief :roll: now to fine a good one :lol:
Posted: Tue Jul 19, 2016 9:02 am
by Chip Birks
madmike wrote:It was the 'Wastegate ' giving me grief :roll: now to fine a good one :lol:
MarioVelotta wrote:Turbosmart :lol:
I share Mario's opinion. I have a TiAl and Turbosmart. Both very good gates in my opinion. The TS is tiny, and had a very nice spring clamp system.
Posted: Wed Jul 20, 2016 5:11 am
by madmike
Thanks Guys,,
Posted: Thu Dec 08, 2016 7:31 pm
by chriswillrise
Ok, new motor got everything buttoned up but cannot get the car to start without carb spray or holding my hand over the carb. holley 2 barrel prepped by aj sims. no vacuum leaks i can find. iver tried everything i can think of and need some help. It runs great spraying carb spray down the carb haha
Posted: Sun Dec 11, 2016 3:33 am
by madmike
Hey Cris,with my sidedraft's I pump it a few times and it eventually starts up :lol:
after it warms it starts right up :wink: does yours do that too?
Posted: Wed May 24, 2017 4:28 am
by madmike
Start up with the Demon 4 barrel is instant :wink: one pump it Firers right up 8)
Posted: Mon Jun 19, 2017 11:39 am
by Ron Perkins
Had an oil leak that turned nasty when I switched to Royal Purple. Looked like it was coming from the flywheel seal but it was on top of the case, thought it was coming through that inspection hole or whatever it is. Pulled the engine, replaced it, put it back in, lead worse than ever. Had to be coming from the shroud oil cooler. Pulled just the shroud, PITA with the turbo set up on. Put a new cooler in, so far so good. Now if it would stop raining in southern florida. 4th week of rain, beginning to remind me of summer in Michigan..only a lot hotter.
Posted: Sat Jul 08, 2017 2:51 pm
by Chip Birks
Just spent the last week doing a quick refresh on my motor, got it all installed yesterday, took pretty much all day. Managed to fire it up today, and after swapping rear tires and lowering it off of the jackstands i noticed a new puddle under it, looked up to see the source and could see a drip hanging from the flywheel side of the motor. No racing for me tonight!
Posted: Tue Aug 01, 2017 5:55 am
by clintonddk
Will changing fuel also change boost pressure?
Posted: Sun Oct 08, 2017 7:11 pm
by seabeebuggy
clintonddk wrote: ↑Tue Aug 01, 2017 5:55 am Will changing fuel also change boost pressure?
No but changing fuel to a higher grade of octane can let you run more boost.
Posted: Fri May 29, 2020 10:06 pm
by CBDZ
Not sure if I have a problem or not. I'm wrapping up my first ever turbo install. I have a used IHI VF-29 from unknown subaru. Don't know anything about the miles on the engine, etc.
I have the turbo mounted at the exhaust inlet. The dump side is still wide open, with the integrated waste gate installed. The oil feed and drain are installed. The boost inlet and outlet side are not connected yet either.
Of course, I had to start it up just to watch the turbo spin. If I place my hand over the oulet on the compressor side, and bring the engine up to speed, i don't feel much pressure. So, my question, do I need to be under engine load? Will I never build pressure free reving
Posted: Fri May 29, 2020 10:53 pm
by 66brm
Correct, boost is dependent on engine load
