Project---Split cable pull linkage
Re: Project---Split cable pull linkage
Looks great Pete mine is working flawlessly. I have only adjusted it twice since I installed it.
Pete. I will take one in black. Need it for a bus so a longer cable would be great.nice to see you back.
Well if pete starts doing the links for himself for a good price i will surely buy one. By the way Pete how much is for one.
He posted more details in the samba post.
Steve
My Baja Build
My Baja Build
- slowtwitch
Passatman wrote:Well if pete starts doing the links for himself for a good price i will surely buy one. By the way Pete how much is for one.
The system is $300.00, plus shipping. The price includes the powdercoating in any color of your choice..as long as it's black
thanks
pete
- 56T4
Been running Pete's linkage for about 18 months now,Best linkage on the market by a long way.And it looks soooo sexy
- slowtwitch
56T4 wrote:Been running Pete's linkage for about 18 months now,Best linkage on the market by a long way.And it looks soooo sexy
Good to hear...thanks
pete
- DaveB
Will be posting my set FS in the forums shortly. Set that came with the acorn nut for the carbs
Pete, anyone who has installed this.
How much clearance is needed between the carbs and the cooling shroud?
Both my Dells touch the shroud.
Bug
2056
Dell 40's DRLA
DTM-V2
Hex bar.
I'm thinking of a couple of those hard spacers between the cylinder heads and the base of the intake manifolds. (if I can find some)
Probably have to use longer studs on the heads
I'm kind of tired of adjusting the idle every time I drive the Bug.
Manny
Bug
2056
Dell 40's DRLA
DTM-V2
Hex bar.
Manny
- slowtwitch
Manny, give me a measurement from center of a manifold bolt to the shroud. I'll see what I haveManny wrote:Pete, anyone who has installed this.
Bug
2056
Dell 40's DRLA
DTM-V2
Hex bar.
Manny
pete
I measure 15mm or 9/16"
That is the best I can see here, both sides are the same.
I took pictures but being a low tech old guy, don't know how to attach.
Pete, yes or yes.
Manny
Manny
- slowtwitch
Manny wrote:Pete, yes or yes.
Manny
Manny, The best I could go is .625 in that measurement with the material I use. I would have to do a complete redesign of the bracket to fit your setup and that would take a bit of time.... which is in short supply right know.
pete
