Page 20 of 21
Re: Joxracing's 1966 Baja "The Resurection"
Posted: Sat Oct 08, 2011 3:44 pm
by Joxracing
in the shop!
only question is... where are all the bolts that hold the body on?
Posted: Sat Oct 08, 2011 6:13 pm
by Big Dave
Joxracing wrote: only question is... where are all the bolts that hold the body on?
Two on top of the front beam, then there is about 12 or so underneath the car that bolt up into the heater channels, then 4 inside the car across the back lip (just behind the battery), and two more on the rear shock mounts. An impact wrench is your friend in removing all of the bolts. ;)
Just remember to disconnect the steering rag joint and bake light switch wires before you lift it up.
Posted: Sun Oct 09, 2011 12:28 pm
by Joxracing
well, that takes care of 12 bolts, since I dont have the heater channel on one side...
thanks.
Posted: Sun Oct 09, 2011 2:51 pm
by Ol'fogasaurus
9 down each side, 4 on the rear cross-piece, two pairs of two on the ends of the front cross-piece accessed from outside/underneath and maybe the two that go in the wheel well to the rear torsion casting w/spacer.
Posted: Tue Oct 11, 2011 5:34 pm
by Joxracing
Body coming off...
Power washing the pan...
What/who's the best bang for buck on replacement pannels?
I need 2 new heater channels, complete & two rear floorpans at the least.
Posted: Tue Oct 11, 2011 6:06 pm
by Ol'fogasaurus
There are at least three pans halves that are available. The Brazilian ones are one piece and are black in color. Very thin but do fit. There is are orange painted pan halves that are available and come in two pieces, the pan and the rear cross-piece; the jack points are separate too. I was able to get mine without seat tracks and heater boxes (that go under the seat on later models), I don't know if it was good timing or they can be ordered that way.
There is now a third style that is OEM in thickness. Other than that I don't know much about them as they came out just after I got mine. As far as which make (and who the makes are) you have to check with who you buy from but unless there is a money shortage, I would get the best I would afford.
One other thing I would suggest would be to make a pattern of the perimeter to ensure a good fit as there can be some fitting that has to be done. This is how it was done in an article in Hot VW mag a couple of years ago and after my fight, I think it is a good idea. They used some flat stock that they cut, welded and bent/formed to the pans shape, marked the locations of the slots in the stock pan.
Some people if the outer perimeter of the pan is OK (the body mount channel) just cut the center floor structure out and replace that. Some even go as far as bending a new perimeter out of 2 inch rectangular stock and replace the outer channel with it welding the floor to a flange on the new perimeter.
I hope this helps.
Posted: Mon Oct 17, 2011 5:28 pm
by Joxracing
Im thinking full pan halves, then making some custom replacements for the heater channels. I just can see spending 150 on a replacement channel, when i could fab something out of tubing.
I found some pan halves on ebay for 62 bucks a side..
Posted: Tue Oct 18, 2011 6:32 pm
by Joxracing
One side cut out....
is the 62 bucks a side to good to be true? they are on ebay...
Posted: Tue Oct 18, 2011 8:27 pm
by Ol'fogasaurus
What color are they painted?
Posted: Tue Oct 18, 2011 9:04 pm
by Ol'fogasaurus
If they are the Garage Pro, they LOOK LIKE the Brazilian pan halves I had origionally. OK but not the thickest of the three available but they will get the job done.
I looked at a couple of other places and the prices ranged from $115 to $145 but the cost of shipping was budget breaking, on place (Pacific Customs) said about $100 per. They looked like the same ones you might be getting.
Posted: Wed Oct 19, 2011 4:37 am
by Joxracing
http://www.ebay.com/itm/Garage-Pro-New- ... es&vxp=mtr
62 bucks and free shipping? legit? ha.
the right side is 102... go figure.
Posted: Sun Oct 23, 2011 6:02 pm
by Joxracing
its bare.
those pans look legit?
Posted: Sun Oct 23, 2011 7:23 pm
by Lotrat
Maybe. The cheap ones are thin and the thin ones are cheap. Buy the heaviest ones you can find.
Posted: Sun Oct 23, 2011 9:13 pm
by CentralWAbaja
The thick ones are twice the money Jox...you decide.
Posted: Mon Oct 24, 2011 1:31 pm
by Joxracing
Gonna be going with full pan halves from Mid America. around 110 a side. look pretty thick, 18 gauge i think?
Gonna be fabbing custom heater channels out of some 2" tubing to save money on buying replacements. They'll be tied into the torsion housing and possibly the framehead. It'll be a good base for tie-in's to the show cage too.
