VW Gear Box Codes & Gear Ratio's
- david58
Re: VW Gear Box Codes
2088bob
i have a trans stamped as follows can't figure this one out AH 30 33 891 ???????
i can figure out ones stamped like this AT 02 03 6 produced 2nd of march 1976
Bruce2
The numbers after the AH are just a meaningless serial number. They dropped the counter serial number in favour of the date serial number in late 1972. Thus, your AH was made before then.
2088bob
Thanks a bunch Bruce the AH is a double side cover case so i am having the AT built into a maxflyer 3.88 0.89 4th super diff and the good weddle reinforced side that should stand up behind my bunny motor for a while and drop my hiway cruise RPM just a bit
i want to try the royal purple gear oils any input???????
and yes Bruce its still snowing here in ontario supposed to get 5 cms Saturday my daughter is headed for BC next week
2088bob
AH should have small diameter cross shaft AT should larger diameter cross shaft correct
Bruce2
Snow! People are starting to open the windows in the transit trains here.2088bob wrote: and yes Bruce its still snowing here in ontario supposed to get 5 cms Saturday
I have one AH SSC gearbox with the large cross shaft, so you can't say all AH have the small shaft. Also, I have had DSC AT gearboxes with the big shaft.
To date a gearbox with only numbers and no letters in the code, go here:
http://www.thesamba.com/vw/archives/inf ... dating.php
- david58
Re:
The link is dead.turboblue wrote:http://sandlizrd.baja.com/gears.htmdooker wrote:any place i can find Type 2 gearbox final drive ratios? thanks.
Found it in search
http://sandlizrd.baja.org/gears.htm
Bruce2
Re: Re:
Yep, code is AW. Same spec as above.vwbilly wrote:Is there a thing trans that came with an OE 4 spider diff??Bruce2 wrote:That is a Type 181 open diff gearbox.bedjo78 wrote:I got AV code on SSC type1 , please what is the ratio of the gear
4.12 R&P
3.78
2.06
1.26
.93
- sideshow
Re: Re:
No.There was a plate type LSD or the more common 2 spider style. 4 spider diffs were made by a few aftermarket places with random reviews.Is there a thing trans that came with an OE 4 spider diff??
- birddog1148
Re: VW Gear Box Codes & Gear Ratio's
So this is a good code?
CA0468993
supposed to be a bus box. Will it hold up to a stock ecotec of EJ22 Suby on a Baja 235-75 R15 tires?
CA0468993
Aart-Jan
- rsw
Just checked the numbers on my trike and they are AH 4659. Everything I find says it's a IRS, but it's a swing axle. Any thoughts?
Bruce2
It is an IRS gearbox that has been converted to swing axle.
