How big can we go with the WBX?
- Unkl Ian
They make sleeves,and machine blocks.
http://www.darton-international.com/mainpage.htm
If you can't find a production sleeve that will work,
they can custom make whatever you want.
There are differing opinions on that.pocketrocket wrote:The WBX flywheels are NOT forged. Cast steel.
It has yet to be convincingly proven either way.
So far, Pocketrocket (a highly respected member of the board, and a fellow I don't wish to piss off) feels they are cast steel.
Jake always says they are forged.
I strongly suspect they are forged... Here's my reasoning.
I have yet to hear of anyone, anywhere having issues with them, ever, even used at >600HP and 8K.
I STRONGLY suspect if they were cast, we'd have them fragging left and right in Hipo use, or at least getting dorked up at the flange, which ~doesn't happen. The design lends itself to abuse well.
It WOULD be nice if QSC or someone would make a forged CrMo 228 for a reasonable price and remove all doubt..
(I made an email request, FWIW, maybe if more folks asked, they'd do it, they sell ~6 different PP/disc combos for 228mm)
If in doubt, Kennedy will happily make you one.
- sideshow
But why run 228mm? Outside of late bay bus I am guessing they are not that popular. For the more common bug gear boxes the 215mm make more sense to me, near the same clamping as a Kennedy stage 1, near the same little pedal effort, and a sprung center.
Or use the 200mm conversion flywheel so you can run nearly any clutch cover.
I swear there is a difference between what I assume is a 1.8l bus flywheel (from Jake's store) and what I assume is the original flywheel from 1983 1.9 wasser core.
Dirty
Clean
The cast verses forged debate maybe be too simple, after all the crankshafts are made of a mild steel in theory they should be exploding left and right.
Dirty
Clean
In a T1 trans, fitting a 228 is a PITA, and usually not needed.
If fitting a Bus or 914 trans, or if you have a need for a 9" clutch and a trans that will take the power, it is an option.
- Wally
Which can be fairly easy to put behind you. I didDORIGTT wrote:I'm the idiot trying to run a 915 which has its own set of problems
I do dragrace starts on M&H slicks with them on a stock mag cased 915 with a stock and very old pp and new disk only. Still amazes me too I must admit.
And drive it on the street and track as well.
Kennedy flywheel 915-> type 4
- Wally
Exactly! Most don´t realize that! `An aluminium case is stonger you know`...DORIGTT wrote:
The magnesium cased model - weighs less and has the steel inserts for the bearings so apparently the saddles won't oval!
Sure it is
