Lotrat's Budget Baja Build
Lotrat
Post by Lotrat »
namelesswonder wrote:
Lotrat wrote:I won a major award a while back. I just haven't installed it yet. :oops:
Check it out....
http://www.shoptalkforums.com/viewtopic.php?t=121068
That is the most ridiculous contest ever and I can't believe I didn't see it when it was happening!
What's really nutty, is that the prize is worth more than my engine...
Hedrock
Post by Hedrock »
Check it out....
Send it back then and I'll end you an autographed photo of Leatherneck sport'in his fancy brain bucket...
Image[/quote]
I know you need some time to think about it... :lol:
I didn't think we was supposed to post porno on here. :shock:
Lotrat
Post by Lotrat »
I sure would like to see his bumper.
petew
Post by petew »
Lotrat wrote:I sure would like to see his bumper.
WROOONNNGGG!!!!! :oops:
Is there anything else you'd like to see. :roll:
Lotrat
Post by Lotrat »
So I FINALLY made an attempt at installing the bling (Serpentine Belt System) I won awhile back. Took forever to get the Scatt sand seal. No one stocks it locally. Anyways, I get the generator pulley on, press in the sand seal, bolt on the crank pulley, and then come to the serpentine tensioner. The instructions say to remove the front two generator stand studs. :evil: What the heck! I'm not in the mood to take everything apart to get those studs out. Guess I'll see if I can find a pair of low profile nuts to get them out.
Newest member of the Baja's that are not running club...
Just for giggles see if you can't get two (other) nuts on there, lock them together and see if the stud will come out. You could get lucky. You are probably due.
see what happens when you win a STF contest..... :lol:
Lotrat
Post by Lotrat »
Two stripped nuts... Time for some heat.
This is one of those simple things that turns ugly. I can feel it in my bones.
Lotrat
Post by Lotrat »
So I was right... It got a ugly, but not the way I thought. I got the studs out with some heat and a stud remover. I put the whole thing back together and find that I have an alignment issue. My generator is 10mm out of alignment. :evil:
Ken at MST said I need to pull my generator and fan shroud back 10mm to get it into alignment, but there isn't any slop to do that. I don't have 10mm behind my carb. The assembly won't move that far anyway.
I have the issue posted in the T1 forum if anyone has some insight.
http://www.shoptalkforums.com/viewtopic.php?t=122169
rickosuave1987
Post by rickosuave1987 »
Cant you just shim out the genny pulley? :?
Baja
HookIt
SuaveRacing FaceBook
Lotrat
Post by Lotrat »
rickosuave1987 wrote:Cant you just shim out the genny pulley? :?
Not 10mm's. The generator stud is only 10mm long.
I had the alignment issue with my stock pulleys too. I just kept a spare belt in the car. I thought it would have been chewed up, stretched, or broken by now. I have a few thousand miles on the car and the belt never even loosened up, so I just left it alone. The serpentine belt isn't so forgiving. I need to get the pulleys within 1mm.
i'll give you 23 bucks for it and you pay the shipping :wink:
CopperBaja
Post by CopperBaja »
Sounds to me like it's time for an alternator conversion! :D
I'll give you 23.01 and I'll pay for shipping.... :lol:
