All Torque - 1956 Oval Turbo Wasserboxer Update...
marcotheturbosteamengine
Re: All Torque - 1956 Oval Turbo Wasserboxer Update...
Post by marcotheturbosteamengine »
Passatman wrote:What's the advantage to using a 3 piece valve in an engine.
The head is designed for very high temp so it dosent melt, the stem is designed for good heat transfure and ware cateristics, and the tip is designed hard for the rocker tip to slide againest
DORIGTT wrote:What's special about the crank?
nothing, just a good standard 76.4 mm Okrassa crank (where Berg got his cranks made, he wasent stupid :) ) the materal is top notch :)
tencentlife
Post by tencentlife »
Read this:
http://www.enginebuildermag.com/Article ... lloys.aspx
Happy holidays everyone!
Okrasa(now Oettinger---crank made by Alfing) counterweighted crank, made by German elves from the finest German steel...
I have a 74mm T4/55mm rod journal version (now with custom 5.3" Crower rods) that will see use RSN...
Thing of beauty. Absolutely the opposite of Chinese quality. :lol:
Alfing still makes cranks for Porsche/Ferrari/F1/NASCAR
Their MAIN buisiness is they make the machines that many OEMs make their cranks on.
Think Moldex, only better.
IIRC most of Bergs cranks came from Swedish Elves, awesome quality too.
Passatman
Post by Passatman »
Whats the quality like on a stock water boxer crank. Reason for asking is i have a waterboxer and want to rebuild it one day as a turbo monster.
tencentlife
Unparalleled quality.
DORIGTT
Post by DORIGTT »
tencentlife wrote:Unparalleled quality.
Which crank are you referring to?
Also, do current Berg cranks come from the little Keeblers in the Black Forest?
Only options for WBX cranks are to have them balanced and or counterweighted by someone right?
Passatman
Post by Passatman »
I am wondering if the stock crank can take 600 WHP. Also for a radiator i wanted to build a 12' x 13' x 5'. I saw something on the net that stated that for a radiator of 780 cubic inches i should be able to cool an engine making 780 hp, that equates to 1 hp per cubic inch.
70dragbug
Post by 70dragbug »
Awesome motor and an awesome car congrats Mat and Marco and thanks for sharing the video I really enjoyed it!
IIRC only the german made wbx had their cranks and rods made by Oettinger, engine codes MV and DJ and the 1.9L wbx also.Oettinger only makes inline cranks and engine kits (VW Golf) now.However if you want a good quality wbx crank that is available as a new replacement item you can buy them from Limbach.They make wbx aircraft engines.The cranks,case,rods and heads are exceptional quality.
I wonder if Alfing is still making those cranks for Limbach...
(Oettinger//Okrasa ordered them from Alfing)
DieSchnelleKafer
Post by DieSchnelleKafer »
hi there, wow. thats all i can say.
you have really refined the whole art of sticking these engines in beetles, with great succes aswell.
would you be able to show some more pictures of this bug including the cooling system? and some more over all shots?
love it to bits mate,
thanks
-Blair
Typ 11 Beetle
Post by Typ 11 Beetle »
Limbach is going to close their shop , if you want any parts from them , now is the last chance.
Passatman
Post by Passatman »
When is the final date for them before they close.
