Problem of the day. Post it up!
- Zander
Re: Problem of the day. Post it up!
That sucks Shag! I had one of those chrome alternators bad out of the box recently. Totally sucked, replaced it and all is good now. Just seems like those are hit and miss.
BTW my turbo I got from you has been nothing but awesome!!! Thanks for the great product.
- seabeebuggy
I went through 3 new Bosch before I gave up and went to AC.
Steve Arndt
Shad, did your 300$ compufire alternator die?
s
s
shag55
Glad Zander! What times you running now?
Yea the alternator went out. Regulator fried. Just rebuilt it. It's going back together now. Put on a regular bulb and going to try a interstate battery.
Shag Leone, SL-1 Racing
325WHP and 290TQ @17# on 91oct
383WHP and 324TQ @23psi on 50/50 mix
What's next?
Need a turbo or parts!
[email protected]
Facebook at SL 1 racing
What's next?
[email protected]
Steve Arndt
That is how I roll, but mostly because the shop has an Interstate account.
I still have to believe that something else is wrong to have this many problems in a row. You need a line mechanic friend with a volt meter lol. I hate to bring up the swapped 3/4 coil wiring because of the coil labeling... okay that was a low blow. I really hope you get it dialed. Now post those pictures.
s
s
- Zander
Best to date is a 12.1 @ 113. Done a lot of changes, running e-85 now. I know its got an 11 in it, just need to break it out and go racing! Been building a bus for the family. Speaking of bus.....do you make a turbo header to accommodate the rear engine bar on an early bay?
shag55
I have a volt meter. Just don't know how to check amperage draw.
What's next?
[email protected]
What's next?
[email protected]
Steve Arndt
You need a multi meter with an Amp setting. What kind of meter do you have?
shag55
What's next?
[email protected]
What's next?
[email protected]
Steve Arndt
What type / model of volt meter do you have?shag55 wrote:I have a volt meter. Just don't know how to check amperage draw.
shag55
Will check tonight. I will probably just get her back together and take it down to the auto electric shop to test it.
What's next?
[email protected]
What's next?
[email protected]
- turbobaja
So close to the first start up on my 8 year build I could almost taste it. All systems primed and cranked to check initial timing....no spark. My overpriced MSD distributor came with a bad pickup coil
Tonight it shall be a runner!!!
Karl
DON'T QUIT
DON'T QUIT
- MarioVelotta
Woot!!! I bet your nerves are shot double and triple checking everything
[email protected]
[email protected]
- turbobaja
Ya, just a little burnt out. After pushing so hard to get this thing going, and finding problems with almost every system as they come to life, confidence is a distant memory. I'll be lucky if I don't pass out during the cam break-inMarioVelotta wrote:Woot!!! I bet your nerves are shot double and triple checking everything
Karl
DON'T QUIT
DON'T QUIT
shag55
Good luck Karl!
I on the other hand am going to burn my car if I can't find out why I'm having alternator problems. I put a regular bulb, a new interstate battery and rebuilt the alternator. 1st start up went good. Light went out. Charged at 14v and seemed fine. After turning off and restarting I had to rev it to get light to go out. Next time it got worce. Damn! What is going on here.
Took it to alternator shop and he said my wire must be bad. He said it should read 5-7 volts WHAT! I tested two stock bugs and both there wires read 11.7v and 11.6v and mine is the same. Why is my alternator not getting excited?
What's next?
[email protected]
What's next?
[email protected]
