Looks like I was missing some harness bits. I was missing the female connections from the motor harness.(injectors/knock/crank etc) I picked these up at the wrecker but I think I have the wrong relays. Can someone verify? I think the one with the green plug is correct but I couldn't find that square brown relay one.
Also can someone confirm where these (A B C ) go? I stole this from RonW hope he doesn't mind. I forgot to snag a pic of mine. RonW or others, where are your oiling your turbo now that it's in front and where are you getting your coolant line to and from the turbo?
panel, please use whatever you need i've posted. sorry for the delayed response
A - capped oil return from turbo - new set up is dumped into bung welded to oil pan.
B - new feed to turbo. i had to use a piece that Forced Performance makes that works with the bango fitting on my rig that uses AVCS system. there is a -4AN fitting on the outer end that I then hooked my pressure line to the turbo. Since your system is different, you may be able to just pull from where the oil pressure sensor is located? then it would be a much shorter run depending if you turbo is located at the crank pully. the stock set up is the top of that hardline is then capped.
C - tubro coolant feed (coolant return is to top of turbo tank)
RonW wrote:B - new feed to turbo. i had to use a piece that Forced Performance makes that works with the bango fitting on my rig that uses AVCS system. there is a -4AN fitting on the outer end that I then hooked my pressure line to the turbo. Since your system is different, you may be able to just pull from where the oil pressure sensor is located? then it would be a much shorter run depending if you turbo is located at the crank pully. the stock set up is the top of that hardline is then capped.
Wonder if this would be a good spot to mount an oil pressure sensor ?
possibly. the oem spot is right above the oil pump and probably the most instantaneous and accurate location. i just put a sandwich plate at the oil filter for the axillary dash gauge.
did you contact outback about the header? what did they say?
panel,
a guy on fb posted pics of his bus with a EZ30 in the back with dual rads. dont know what kind of air scoop he is running to divert air in but just though it might be helpful. if you find out what kind of rad this is, post it up
First one is behind the intake. Can't remember what I took out of this hole?
And this one is a breather line that is 'T''d between the two valve covers and pokes out the right hand side and faces you between the intake and water cross over tube.
