Starter fo 2.2 Subaru in '73 Superbeetle ?????
- Prtexx
Re: Starter fo 2.2 Subaru in '73 Superbeetle ?????
When I get home tonight I will look it up and post it for you. Worked really good and with the TDI starter you can get a socket on the second bolt.
Steve
67 VW roadster
36 Buick 3 window coupe blown 350
87 Syncro 2.5 Subaru
84 Westy
77 Westy 2.5 5 speed
FB VW Subaru Conversions
67 VW roadster
84 Westy
- Prtexx
Autozone starter part number 17305 $126 including core charge. Has been working great with no issue I believe it is a Passat TDI 2001.
Steve
67 VW roadster
84 Westy
67 VW roadster
84 Westy
- 59Bisquik
Thanks! I will order one up Friday!
Recap just in case:
Jetta VR6 automatic w/9 tooth gear starters fit T1 transmissions. (manual and T3 automatic, probably 411 as well, not 100% sure on latter.
Did they sell TDis with automatics? Ugh... they probably took the same starter.
The TDi manual starters fit 091/094 and 090 autos and 914/911 transmissions as they have a deeper offset. IIRC they need a spacer as well.
- 59Bisquik
002 and Type 1 take the same starter, correct?
99% sure of that, as long as the bell housing etc was not swapped for an 091 for T4/228mm FW use.59Bisquik wrote:002 and Type 1 take the same starter, correct?
(I have a trans like that, somewhere)
skills@eurocarsplus
so, to clarify, the bosch SR0407X starter is the preferred choice for the subaru swapped cars, correct? i need to oder one. it seems to fit most TDI automatic's with a 9 tooth pinion. just want to make sure before i order one
thanks!
thanks!
SR0407X confirmed.
skills@eurocarsplus
Thanks! That's good to know. Other than filing the holes, it is a "direct fit" (haha...like any part of this swap is direct fit!)
- panel
Can I run an 11 tooth starter ? 12v flywheel etc. I can get one locally and want to jump on it but if it work then I'll pass.
9 tooth only. 11 tooth will just munch the flywheel.
- panel
^ Thx !
R2.0
Tagging for future reference - I have a 914 transmission I'm going to be swapping into my Karmann Ghia.Piledriver wrote: ↑Mon Jan 27, 2014 11:09 pm Recap just in case:
1972 Karmann Ghia Convertible
"As God is my witness I though turkeys could fly." - A. Carlson -
- panel
That be the one, you'll need to spend a few minutes with a rattail file or such to move one of the bolt holes, but its worth it.
It centers on the big round hole in the trans, not the bolts.
Thanks for the link, I need another one anyway, put the one I had on the square in the vanagain to spin over the 3.6/6 on the automagic trans... yes, I just bought one. Works on automatics just peachy too.
I think I tried it successfully on a 914 and 091 trans as well. Has lots of throw.
