71 bug - planned EJ20t swap - new member
Prtexx
Re: 71 bug - planned EJ20t swap - new member
Post by Prtexx »
quick Google search says this but double check to make sure.
Year Make Model Trim Engine
GAS;; Qty needed per... 1991 Chevrolet Blazer Scottsdale Sport Utility 2-Door 5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated
GAS;; Qty needed per... 1991 Chevrolet Blazer Silverado Sport Utility 2-Door 5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated
GAS;; Qty needed per... 1991 Chevrolet R1500 Suburban Scottsdale Sport Utility 4-Door 5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated
GAS;; Qty needed per... 1991 Chevrolet R1500 Suburban Silverado Sport Utility 4-Door 5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated
GAS;; Qty needed per... 1991 Chevrolet R2500 Suburban Scottsdale Sport Utility 4-Door 5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated
GAS;; Qty needed per... 1991 Chevrolet R2500 Suburban Silverado Sport Utility 4-Door 5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated
Steve
67 VW roadster
36 Buick 3 window coupe blown 350
87 Syncro 2.5 Subaru
84 Westy
77 Westy 2.5 5 speed
FB VW Subaru Conversions
Prtexx
Post by Prtexx »
This is better has gates listed, requires a little trimimng but works great.
Cross Interchange Parts
Factory Number
NAPA 8338
GATES 21620
CARQUEST 21620
RoadMAX C1620
Fresh ... 418
Steve
67 VW roadster
84 Westy
jrobe
Post by jrobe »
I think my radiator is from a Toyota mr2 spider, 2001 or so.
Its not in so double check dimensions.
ryans88gt
Post by ryans88gt »
Sounds like something in the 26" x 18" high should work maybe? I'll have to measure.
Went out and purchased an electric body saw to make opening up a new home for the radiator a little easier.
Also picked up a couple chunks of 3/16" sheet steel at the local steel shop. Will be used for various fab work.
Continuing to collect parts!
ttriebler
Post by ttriebler »
Lol not too many Chevy Blazers or Suburbans in Australia but the Gates number will do it. Cheers!
surfbeetle
Post by surfbeetle »
Read though my thread, the link is in the signature. As for the radiator, the size from a Sirocco is a good. I got mine from speedway motors.
_______________
'67 Bug EJ20 Turbo
Build Thread
ryans88gt
Post by ryans88gt »
surfbeetle wrote:Read though my thread, the link is in the signature. As for the radiator, the size from a Sirocco is a good. I got mine from speedway motors.
I did previously read through your thread and a lot of good information in there, I like what you did/are doing with the rear package tray area. I may attempt something similar.
How close are you to having the car finished?
jrobe
Post by jrobe »
The mr2 radiator is 25 1/2 x 12 1/2
surfbeetle
I hope to get the car over an exhaust shop in February to have the coolant lines made. That's my major roadblock right now.
_______________
'67 Bug EJ20 Turbo
Build Thread
ryans88gt
Post by ryans88gt »
Well got the motor today. Time to start taking it apart. A little concerning that I can turn it over easily by hand with very little compression... but I didn't check to see if the plugs were in it. Lots of little things to look at. Recommendations on what to check out before the warranty expires? I was going to pull the pan and valve covers and check things out and do a leak down test.
Not sure what else can easily be checked without having it ready to run in the car.
panel
Post by panel »
Are you going to run the OEM ECU? Also take lots of plumbing pictures of the oil lines, water lines and fuel,vacuum etc. Some you'll eliminate but when you start to disassemble / assemble this will help a lot. I'm ok now on my project but wish I had taken more.
ryans88gt
Post by ryans88gt »
panel wrote:Are you going to run the OEM ECU? Also take lots of plumbing pictures of the oil lines, water lines and fuel,vacuum etc. Some you'll eliminate but when you start to disassemble / assemble this will help a lot. I'm ok now on my project but wish I had taken more.
No... seemed like way too much work to get a complete unhacked harness and computer. Just going to do microsquirt and build a custom harness and relay panel. Yeah there is a lot of stuff on the motor. Probably get a chance to play with it this weekend.
ryans88gt
Post by ryans88gt »
Well, I got the subaru motor broken down to the long block. Did a leak down test and the rear drivers side cylinder has 50% leakdown through the exhaust valves. Front drivers side cylinder had about 20% leakdown but also with the majority of the leakdown coming out of the exhaust valves. Also, looks like the turbo wasn't original on the motor and has some shaft play and lots of oil in the volute outlet. And to wrap it all up, one of the valve covers was cracked. Bottom end seemed strong, other side had less than 10% leak down.
So feeling a little disheartened.
Buggin_74
Post by Buggin_74 »
I wouldnt feel too down, a head freshen up is likely all it needs, head gasket on that side may have gone and got it a bit hot previously.
You said its covered by a warranty?
ryans88gt
Post by ryans88gt »
Head gasket seems fine, exhaust valves don't seat. Seems like a common issue with the turbo motors when the mixture has gone a bit lean. Looks like the turbo inlet was ripped, so that would explain a lean mixture. But wasn't planning on tearing the motor apart. Soooo... yeah, working with the supplier to see how they are going to help out. Supposed to have a 30 day warranty. I sent them a video of the trashed turbo and failed leak down. Waiting to see what they say. Can't imagine how they say this passed a compression test.
http://youtu.be/7fazjkPFylg
