2450 (78mm x 100mm) engine build
bushoarder
Re: 2400 engine build
Post by bushoarder »
That’s a very nice spec and seems quite mild yet powerful.
Are your spark plugs relocated too?
What is the cam grind similar to? Scat c35 or similar?
I’ll read your other thread too as it sounds a good powerhouse.
My bus engine (was for my bug but bus came first):
1800 industrial engine with 41x34 valves and 40mm webers.
Home made Cali conversion
I got the aa flywheel too - really nice.
It pulls ok, needs rolling road, but I want more power. Sounds like I could enlarge to 1911 easy enough and perhaps approach 90hp without a cam change.
I’ve got a pile of type 4s to make up a new motor and thinking the 2l is a good start, I’ve got a pair of heads with bigger than 42x36 valves my friend donated, web86b (or c35), some 96s and various new type 1 pumps.
Just need to do something about it!!
Eddie010
Post by Eddie010 »
bushoarder wrote: ↑Fri Nov 30, 2018 11:54 am That’s a very nice spec and seems quite mild yet powerful.
Cam is older profile 316°,lobe center 105, with lift off 8,50mm. Lot of people say that they don t use those cams because of the low lift,
that robs power... but hey at the time of the built I thought this was a good cam..
Don t know if that is similar to C35 cam.
Nope standard CU heads so sparkplug at it s original location.
If you have parts of a 2.0l engine, I would use those.
Regards Edgar
Eddie010
Post by Eddie010 »
Ok looking for some valve spring options.
https://www.csp-shop.com/en/engine/valv ... 4961a.html
These look ok too.
Is the pressure at lift ok for a webcam 86b?
Regards Edgar
Tony Z
Post by Tony Z »
I've just bought beehives for mine.... but wont be assembling for a few months
see aircooled.net
wreck
Post by wreck »
I used PAC 1286 beehives with longer valves , installed height of 1.75" . I had to space the rockers out quite a lot and open the pocket up a small amount
. . If Dan's kit had been available when I was sourcing parts I'd most defiantly gone that way .
Clatter
Post by Clatter »
The cam will determine the springs.
I don't know those cams.
Johannes will be able to tell you if his springs will work with that cam.
An 86B is supposedly dual-spring only, but -can supposedly- be run with beehives using 1.3 rockers and light valvetrain components.
Spec out those JPM springs to the ac.net beehives to know for sure.
If you are using aluminum pushrods, (titanium retainers?)
And the ramps are as gentle as they are supposed to be with that Schleicher cam,
I'd venture my uneducated guess that you're on the right track.
Regular old Scat or Bugpack singles would fit over the Type 4 guide boss with light hand pressure.
They would live fine like that because they grow outward on compression.
The beehives fit over the boss only with machining.
I'd bet those JPM springs are a different animal altogether,
And will require machining to the boss.
But, it's just a little bit, so better than duals for keeping the guide supported and in place.
Eddie010
Post by Eddie010 »
Thanks for the info guys.
So engine is out.
Ready to start building a new one.
Eddie010
Post by Eddie010 »
Because the website where i put my pictures is down the pictures in here are also down..
sorry for that
Eddie010
Post by Eddie010 »
Ok got Al the parts now.
Went with JPM single springs + Titanium retainers, on advise of Johannes.
Busy with cleaning of the case.
The case / heads are ready to be machined.
Using the heads of 2.0 engine, only 10.000 km on them.
Valves were not leaking... Never cc the heads, did this now they are off...
They are all 45cc just what I was told when I had them built for the 2.0 engine. ;D
Clatter
Post by Clatter »
Nice!
Thanks for taking time to post up.
FWIW,
Maybe take the time to port the case windows?
Free is free, right?
Eddie010
Post by Eddie010 »
Oh Wil take a picture of that, but I did make those corners rounder and smooth..
Eddie010
Post by Eddie010 »
Just removed the sharp edges
Eddie010
Post by Eddie010 »
Had some time to go to my friend, he has a ships engine repair shop.
Made the test deutz cylinder to the size I wanted.
1 step closer to building.
PS I now this is not the correct way to cut the cylinders, but this is the test cylinder.
Eddie010
Post by Eddie010 »
After some info and advice, I am going for heads 113mm and case 107mm (106mm).
So Cylinders will be 0.2mm less.
Removed a little bit to much from bottom... but this is the test Cylinder.
And haven t decided yet if I go 107 or 106mm..
Eddie010
Post by Eddie010 »
Case and heads are out to be machined.
