Custom a-arm suspension
Re: Custom a-arm suspension
Its complicated but you are right on the half-shaft/drive axles having to be longer or shorter depending.
The bus trans being wider than the stock sedan transaxle is one piece of the formula and the length of travel you are intending can also make a difference... up to the point of interference between the drive axle vs. the trans and/or stub axle. The trailing arm for length (for longer travel) and/or width (for a wider wheel base) or a combination of the two is another factor.
I seem to remember that there was/might be trailing arms for a narrower width/wheel base also but I am not completely sure that they are still doing that.
vw1970
Post by vw1970 »
I've made a it of progress in the few months since my last post which is really nice to see since it's starting to look like a car now!
Here's a few pics of the rear suspension setup partially welded in place. everything is within tolerance within reason and prior to welding. The camber and toe measurements are within .5* of target in initial setup.
also got the new trans mount in place to fit the new bulkhead and place the driveshaft higher in the tunnel to correct the output angle of the driveshaft that mounts up at 1* from square with shift tunnel.
engine is mostly a long block aside for making a few modifications to a few components to account for the altered ground clearance
ImageIMG_20190831_190919 by Travis L, on Flickr
ImageIMG_20190831_190745 by Travis L, on Flickr
vw1970
Post by vw1970 »
put the body back on this weekend and mounted the rear tires and i'm happy with the camber angles and tire placement but am not super happy with the fender gap. will probably need spacers which are widely available for subaru aplications and can scoop some up down the road sometime. next ill be looking at the front suspension layout and deciding where to mount the steering rack, front diff and springs
ImageIMG_20190908_163450 by Travis L, on Flickr
panel
Post by panel »
Looks like you're building a SEMA car !
vw1970
Post by vw1970 »
panel wrote: Thu Sep 12, 2019 9:46 pm Looks like you're building a SEMA car !
Thanks Panel, that means a lot coming from you! I believe we've had interactions on the samba in various ways regarding my mega squirted car prior to this build and you've been nothing but extremely professional, Cheers! Here is said car;
ImageIMG_20160923_144405 by Travis L, on Flickr
here are a few updates.
Finally got the engine buttoned up. It's a 2009 Sti short block from Subaru in a fancy Subaru crate and some ej205 heads that I had laying around. This combination would in the Subaru performance community be called an "hybrid" engine. The turbo pictured is a gt3071r eBay clone with a .63ar hot side, billet compressor wheel and v band outlet at $400 is a sweet little starting turbo that flows lust a little more than an OEM equipped turbo for this engine. I fabbed up the header trying to simulate the uneven header that causes that subi rumble that everyone loves so much! It was also my first time designing and 3d printing mitter templates in solid works. I think the modeled collectors came out sweet? I'm still getting the odds and ends shorted and I'll add photos of a few of those things as i get to them.
ImageIMG_20200326_134727 by Travis L, on Flickr
ImageIMG_20200328_180703 by Travis L, on Flickr
ImageIMG_20200417_183040 by Travis L, on Flickr
panel
Post by panel »
Almost the same exhaust !!!!
CBDZ
Post by CBDZ »
Very nice.
Any pictures of these miter templates? I am working on an exhaust system too, and thought about making bent section, collector, and miter templates in Fusion 360, and 3D printing them as well.
My Car Details:
Fiberglass Buggy on 1973 Chassis.
1904 cc
Megasquirt (MS1 with 3.57 board) Fuel Injection: German Intake Plenum, CB Performance End-Castings, Ford Escort Throttle Body with custom Adapter, MS controls Wasted Spark Coil Pack
vw1970
Post by vw1970 »
Haha it looks like great minds think alike panel! you have a link to you build thread?
CBDZ wrote: Mon Apr 27, 2020 9:48 pm Very nice.
I like solidworks but only because that is what im familiar with. The templates are split down the middle clamshell style since they wouldn't slide onto the end of thepre welded long section. super simple to model actually. Here's a few pics of the process for you;
ImageIMG_20200326_140036 by Travis L, on Flickr
ImageIMG_20200326_130203 by Travis L, on Flickr
ImageIMG_20200326_122048 by Travis L, on Flickr
ajdenette
Post by ajdenette »
That is some creative use of 3D printing I like it!
Alex
|_________oo_oo
/ /__/____[_____\
I I======[]IIIIIII[]
()_)-----()_)----)_)
assign
Post by assign »
I would love to purchase your files/ plans for your suspension. Please let me know if you are interested.
Thanks!
panel
Post by panel »
vw1970 wrote: Thu Apr 30, 2020 8:07 am Haha it looks like great minds think alike panel! you have a link to you build thread?
Check the link in my signature for my build thread.... :)
vw1970
Post by vw1970 »
here is a long over due update pic with no explanation;
ImageIMG_20211022_193831 by Travis L, on Flickr
panel
Post by panel »
Beautiful !
GaunchLauncherII
Post by GaunchLauncherII »
WOW!! what you are doing is amazing. looks perfect and well thought out.
Mid Engine K20
Lo Cash John
Post by Lo Cash John »
WOW!!!!
