Performance FI intake for type-3?
dangerboy
Re: Performance FI intake for type-3?
Post by dangerboy »
I was thinking of running these on a 2270 I have planned, but don’t have the space in my early car. https://vwspeedshop.com/product.php?productid=16821
Max Welton
Post by Max Welton »
Those are neat. Nice set of options and sizes.
Max
dangerboy
Post by dangerboy »
Or if you’re on Instagram look up Jason Eggum. I believe he works for old speed, he could build you an intake set up
Wally
Post by Wally »
Found this on FB:
Specifically for type 3 or so it read:
Max Welton
Huh. I'm not on FB.
Details please!
Max
terryly
Post by terryly »
looks like drive by wire
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Porsche piston squirters
30mm triple "O"ring pump
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
SL-1 Turbo prepped heads
Post by Chip Birks »
terryly wrote: ↑Wed Mar 31, 2021 5:40 pm looks like drive by wire
Your eyes do not deceive you!
Bruce.m
Post by Bruce.m »
OT
Do modern injectors fit in type3 EFI manifolds or do they need modifications? (Fuel rail required obviously but is the injector bore 14mm).
Thx
Max Welton
First gen Ford Focus injectors fit if you remove the pintle cap.
https://www.thesamba.com/vw/forum/album ... ts=summary
Max
Wally
Post by Wally »
Bruce.m wrote: ↑Thu Apr 01, 2021 12:46 am OT
Thx
The original proper fit for 'modern' injectors is a little less then 14.0mm iirc, its 13.9mm I remember once measuring, but all stock type 3 or type 4 manifolds are much smaller. The fit of the O-rings you see in the pic from Max is where the O-ring sits on the tapered part. That works for N/A engines if your fuel rail pushes the injector hard enough in the curved recess of the stock manifold injector bore. If it also still works with boost depends on your boost level and how well your fuel rail is mounted I guess.
But to recap: no, the opening in stock type 3 mani's is NOT the same as modern injector holes. You can get by that however, as the factory did it the same way :-)
The vanagon/"T3" manifold and center plenum will literally bolt on a type 3 DP setup.(pancake t1 motor)
Port match will be way off...
The stock vanagon manifold end castings are steel or iron, so you have several choices how to reshape the transition for port match.
I have a setup if you wnt pics of how the plenum sits on the case. It should clear.
I may even have enough t1 parts to put together a mockup t3, although the t3 cooling system and HX went to a new home...
86+ wasserboxers were 2110s with ~web86 valve timing and dual springs, the high compression Euro DJs were rated at 112HP.
