"Reliable" 300hp Type 1, possible?
- villemil
Re: "Reliable" 300hp Type 1, possible?
Should't like any of those CNC heads flow enough for 300hp turbo setup?
-72 1641cc turbo bug RIP
- richie,uk
Ok but 1st i have to say it was built with mainly what I had laying around leftover from other projects as its a budget build so if i was building something to meet Villemil's needs it wouldn't be the same.
2332 in a mag case, yes EFI[ i wouldn't build something turbo to be used daily if it wasn't] and water/air intercooled, single 75mm TB, 1 5/8 header, older garrett t3/4
- richie,uk
I was figuring it was for a cnc head but not 100% sure, as for engine size, well if I was to choose any size based on his simple 300hp streetable requirements i would recommend going 74x101.6, but also remembering I said i wouldn't use thickwall cylinders anything 92mm bore is a non starterbuguy wrote: ↑Sun Jan 03, 2021 12:18 pm My apology for the confusion. I figured most were recommending something in the 78x92 - 78x94 range. So if we are talking in the 82x90.5 range would the suggestion be much different?
Here is where I saw the 136cc port volume. That may only be for the CNC version. I don't see a specific port volume on the non cnc.
https://www.cbperformance.com/Cylinder- ... 7.htm#CHFC
My own real world example is a 2332 so was basing it off that as I think it works pretty dam well whatever port work and size it has
- richie,uk
- buguy
Fair enough. Keep in mind, all we ever hear is "keep the port volume small to keep air speed up". Pat at CB recommended to me (for a street car) the wedge port heads on a 82x94 because they have a 76cc port volume but still flow fairly well. So when i see a port volume of 136cc you can understand my confusion.richie,uk wrote: ↑Sun Jan 03, 2021 12:46 pmI was figuring it was for a cnc head but not 100% sure, as for engine size, well if I was to choose any size based on his simple 300hp streetable requirements i would recommend going 74x101.6, but also remembering I said i wouldn't use thickwall cylinders anything 92mm bore is a non starterbuguy wrote: ↑Sun Jan 03, 2021 12:18 pm My apology for the confusion. I figured most were recommending something in the 78x92 - 78x94 range. So if we are talking in the 82x90.5 range would the suggestion be much different?
https://www.cbperformance.com/Cylinder- ... 7.htm#CHFC![]()
My own real world example is a 2332 so was basing it off that as I think it works pretty dam well whatever port work and size it has![]()
- villemil
I was thinking on starting a youtube channel and start making weekly vlogs from my journey on building this car. Would you guys be interested?
- woodsbuggy1
As long as you still keep us updated on here.
Kenric
Kenric
- villemil
Well... Sometimes poop happens and yesterday our garage burned down. The project was going really well until this.
Rest in peace my VW Bug
- buguy
Oh no! Sorry to hear that brother.
- rubenski
Damn....
Verstuurd vanaf mijn SM-A515F met Tapatalk
Oh No ,, sorry Ville,
hope it was insured?
- villemil
- rubenski
What happened?
- buguy
