Posted: Mon Aug 20, 2007 10:05 am
A lot also depends on wether it's cast iron or cast steel.
The aircooled VW tech forum for Beetles, Buses, Karmann Ghias, and Type 3s. Get engine, carb, electrical, and restoration help from experienced VW owners.
https://shoptalkforums.com/
I imagine all the latest 4 cylinder motors have 5 main bearings now.Piledriver wrote: Dodge SRT4... 101mm stroke, 50mm rod journals ....
Yep - including your Subys.Unkl Ian wrote:I imagine all the latest 4 cylinder motors have 5 main bearings now.Piledriver wrote: Dodge SRT4... 101mm stroke, 50mm rod journals ....
Which would make life easier on the cranks.
The yield strength is the value where plastic deformation occurs when the material is (i am assuming) subjected to tensile force. Break strength is the value where it ultimately fails. An important factor to consider is the spread between the two numbers. Notice that the cast material shows yield and break at the same value. This is often referred to as a 'brittle' material, which is not suitable for quality crankshaft materials. A more ductile material, such as the 1045 forged, is more suitable, but will be less resistant to bending stresses under load than the 4340 forged. For performance applications, you want a stronger material, with a higher yield strength.terry cloyd wrote:A stock VW crankshaft is made from 1045 forged steel. A Scat crankshaft is made fron E4340 steel. Cast cranks are made from poured steel. Other cranks advertised as being made from 1045 steel were, but they added sulphur during the manufacturing process (sulphur speeds up the machining process= lower cost.
I know ....so what does this mean
Yield Break
1045 forged VW 80K 120K
E4340 forged 122K 144K
Cast 18k 18k and can be as low as 11K
1045 forged/suplhur 33K 75K
Csaba wrote:The yield strength is the value where plastic deformation occurs when the material is (i am assuming) subjected to tensile force. Break strength is the value where it ultimately fails. An important factor to consider is the spread between the two numbers. Notice that the cast material shows yield and break at the same value. This is often referred to as a 'brittle' material, which is not suitable for quality crankshaft materials. A more ductile material, such as the 1045 forged, is more suitable, but will be less resistant to bending stresses under load than the 4340 forged. For performance applications, you want a stronger material, with a higher yield strength.terry cloyd wrote:A stock VW crankshaft is made from 1045 forged steel. A Scat crankshaft is made fron E4340 steel. Cast cranks are made from poured steel. Other cranks advertised as being made from 1045 steel were, but they added sulphur during the manufacturing process (sulphur speeds up the machining process= lower cost.
Yield Break
Csaba
